# Need suggestion on how to share data between Driver and Scoreboard
**URL:** <https://verificationacademy.com/forums/t/need-suggestion-on-how-to-share-data-between-driver-and-scoreboard/41206>\
**Tags:** UVM, uvm-scorebaord\
**Created:** [January 26, 2023, 2:26am UTC](https://verificationacademy.com/forums/t/need-suggestion-on-how-to-share-data-between-driver-and-scoreboard/41206 "2023-01-26T02:26:03Z")\
**Showing post:** 3
**Author:** ![SupposedRobin70](https://verificationacademy.com/forums/letter_avatar_proxy/v4/letter/s/ce7236/32.png) [@SupposedRobin70](https://verificationacademy.com/forums/u/SupposedRobin70)\
**Post date:** [January 26, 2023, 5:49pm UTC](https://verificationacademy.com/forums/t/need-suggestion-on-how-to-share-data-between-driver-and-scoreboard/41206/3 "2023-01-26T17:49:44Z")
_In reply to [cgales](https://verificationacademy.com/forums/t/need-suggestion-on-how-to-share-data-between-driver-and-scoreboard/41206/2):_
Lets say, i have a simple ALU as DUT.The driver sends opcode+(rand)'operands(ex: ADD,6,5) the monitor captures the incorrect DUT response(say result = 8).I am looking for a way to send the opcode+operands(ex: ADD,6,5) from the driver to the scoreboard so that i can implement a checking logic in the scoreboard say “if((drv.op1+drv.op2) != mon(res)) `uvm\_error”.
Can i build another uvm\_component with a analyis\_fifo to act as the link between driver and scoreboard ?
_[View the full topic](https://verificationacademy.com/forums/t/need-suggestion-on-how-to-share-data-between-driver-and-scoreboard/41206)._
