# Multiple UVC's/agents
**URL:** <https://verificationacademy.com/forums/t/multiple-uvcs-agents/28780>\
**Tags:** UVM\
**Created:** [August 31, 2013, 6:07pm UTC](https://verificationacademy.com/forums/t/multiple-uvcs-agents/28780 "2013-08-31T18:07:42Z")\
**Showing post:** 2
**Author:** ![tfitz](https://verificationacademy.com/forums/user_avatar/verificationacademy.com/tfitz/32/3025_2.png) [@tfitz](https://verificationacademy.com/forums/u/tfitz)\
**Post date:** [September 3, 2013, 1:15pm UTC](https://verificationacademy.com/forums/t/multiple-uvcs-agents/28780/2 "2013-09-03T13:15:27Z")
Each sequence instance gets started on the sequencer of a particular agent. So, once you decide how many agents you want, it’s up to your test to decide which sequence(s) to start on each sequencer. Having an array of agents or separately instantiating different agents makes no difference to the test’s ability to start sequences on the resulting sequencers in the agents (assuming the parameterization is correct).
Does that help?
-Tom
_[View the full topic](https://verificationacademy.com/forums/t/multiple-uvcs-agents/28780)._
