# Magic square on system verilog
**URL:** <https://verificationacademy.com/forums/t/magic-square-on-system-verilog/36496>\
**Category:** SystemVerilog\
**Tags:** SystemVerilog\
**Created:** [September 5, 2019, 6:23am UTC](https://verificationacademy.com/forums/t/magic-square-on-system-verilog/36496 "2019-09-05T06:23:04Z")\
**Showing post:** 14
**Post date:** [May 20, 2023, 6:08am UTC](https://verificationacademy.com/forums/t/magic-square-on-system-verilog/36496/14 "2023-05-20T06:08:28Z")
_In reply to [UVM\_geek](https://verificationacademy.com/forums/t/magic-square-on-system-verilog/36496/14):_
The previous solutions are wrong. See [2D array constraint randomization | Verification Academy](https://verificationacademy.com/forums/systemverilog/2d-array-constraint-randomization#reply-110950)
The correct solution is
```verilog
class magicsquare;
  parameter int N = 4;
  rand bit [7:0] a [N][N];
  constraint c1 {
    foreach(a[i,j]) {
      a[i].sum(row) with (int'(row)) == 15; // rows
      a.sum(row) with (row.sum(col) with (col.index == j ? int'(col) : 0))== 15; // cols
      a.sum(row) with (row.sum(col) with (row.index==col.index ? int'(col) : 0 )) == 15; // diag1
    a.sum(row) with (row.sum(col) with (($size(a)-row.index-1)==col.index ? int'(col) : 0)) == 15; // diag2
  function void display ();
    $display ("The value of array is");
    foreach(a[i]) $display("%p = ",a[i], a[i].sum(row) with (int'(row)));
    foreach(a[,j]) $write("%3d ",a.sum(row) with (row.sum(col) with (col.index == j ? int'(col) : 0)));
    $display("\ndiag1 = ", a.sum(row) with (row.sum(col) with (row.index==col.index ? int'(col) : 0)));
    $display("diag2 = ", a.sum(row) with (row.sum(col) with (($size(a)-row.index-1)==col.index ? int'(col) : 0)));
module test;
  magicsquare m1;
    m1=new();
    assert (m1.randomize());
    m1.display();
_[View the full topic](https://verificationacademy.com/forums/t/magic-square-on-system-verilog/36496)._
