# Is there a function used to set the report verbosity level of a component, can using wildcard like set\_inst\_override\_by\_type
**URL:** <https://verificationacademy.com/forums/t/is-there-a-function-used-to-set-the-report-verbosity-level-of-a-component-can-using-wildcard-like-set-inst-override-by-type/36076>\
**Category:** UVM\
**Tags:** UVM, override, set\_inst\_override\_by\_type, set\_report\_verbosity\_level\
**Created:** [May 9, 2019, 2:18am UTC](https://verificationacademy.com/forums/t/is-there-a-function-used-to-set-the-report-verbosity-level-of-a-component-can-using-wildcard-like-set-inst-override-by-type/36076 "2019-05-09T02:18:29Z")\
**Posts on this page:** 2\
**Page:** 1
<div class="post-metadata">
**Author:** ![jalov](https://verificationacademy.com/forums/letter_avatar_proxy/v4/letter/j/258eb7/32.png) [@jalov](https://verificationacademy.com/forums/u/jalov)\
**Post date:** [May 9, 2019, 2:18am UTC](https://verificationacademy.com/forums/t/is-there-a-function-used-to-set-the-report-verbosity-level-of-a-component-can-using-wildcard-like-set-inst-override-by-type/36076/1 "2019-05-09T02:18:29Z")
</div>
I have many scoreboards in different hierarchies, in some cases, i want to control the report verbosity level of all scoreboards;
UVM offers set\_report\_verbosity\_level to set specified component report level, but when i have may components in different hierarchies to set report level, a way to set report level can use wildcard is needed…
thanks for help…
**Post date:** [May 9, 2019, 12:45pm UTC](https://verificationacademy.com/forums/t/is-there-a-function-used-to-set-the-report-verbosity-level-of-a-component-can-using-wildcard-like-set-inst-override-by-type/36076/2 "2019-05-09T12:45:42Z")
</div>
_In reply to [jalov](https://verificationacademy.com/forums/t/is-there-a-function-used-to-set-the-report-verbosity-level-of-a-component-can-using-wildcard-like-set-inst-override-by-type/36076):_
Using et\_report\_verbosity\_level is not really a good approach, because if you are modifying the verbosity through this construct you have to recompile your complete UVM environment. The function et\_report\_verbosity\_level might be useful during development.
But in generak you should define your verbosity when coding your scoreboards, setting the compare details to UVM\_HIGH and the result pass or fail to UVM\_LOW. Then you can set your UVM\_VERBOSITY from the command line during development to UVM\_FULL and during regressions to UVM\_MEDIUM
