# Is I2C protocol abortion a valid use case?
**URL:** <https://verificationacademy.com/forums/t/is-i2c-protocol-abortion-a-valid-use-case/30338>\
**Category:** SystemVerilog\
**Tags:** SystemVerilog, I2C-protocol\
**Created:** [February 5, 2015, 5:40pm UTC](https://verificationacademy.com/forums/t/is-i2c-protocol-abortion-a-valid-use-case/30338 "2015-02-05T17:40:01Z")\
**Posts on this page:** 1\
**Page:** 1
<div class="post-metadata">
**Author:** ![szy0014](https://verificationacademy.com/forums/letter_avatar_proxy/v4/letter/s/ad7895/32.png) [@szy0014](https://verificationacademy.com/forums/u/szy0014)\
**Post date:** [February 5, 2015, 5:40pm UTC](https://verificationacademy.com/forums/t/is-i2c-protocol-abortion-a-valid-use-case/30338/1 "2015-02-05T17:40:01Z")
</div>
I was verifying the I2C protocol and was wondering if it is worth it to see that after I abort the transaction before completion, the protocol doesn’t get affected after it is restarted. There is way to do this in my work environment (as the master driving I2C is a sequence item), but I’m still wondering if there is a valid use case for this in real-time.
I was hoping if more experienced people here ever seen a situation where the I2C protocol need to be aborted ? (being aborted as late as transmitting the last bit in the protocol)
Pavan
