# How to update the register model in uvm, when registers gets updated by the design internally and not through a bus access
**URL:** <https://verificationacademy.com/forums/t/how-to-update-the-register-model-in-uvm-when-registers-gets-updated-by-the-design-internally-and-not-through-a-bus-access/40878>\
**Category:** UVM\
**Tags:** UVM, assertion, RAL-UVM-PREDICTOR\
**Created:** [September 28, 2022, 7:15am UTC](https://verificationacademy.com/forums/t/how-to-update-the-register-model-in-uvm-when-registers-gets-updated-by-the-design-internally-and-not-through-a-bus-access/40878 "2022-09-28T07:15:08Z")\
**Posts on this page:** 3\
**Page:** 1
<div class="post-metadata">
**Author:** ![SumanthKumarReddy](https://verificationacademy.com/forums/letter_avatar_proxy/v4/letter/s/8edcca/32.png) [@SumanthKumarReddy](https://verificationacademy.com/forums/u/SumanthKumarReddy)\
**Post date:** [September 28, 2022, 7:15am UTC](https://verificationacademy.com/forums/t/how-to-update-the-register-model-in-uvm-when-registers-gets-updated-by-the-design-internally-and-not-through-a-bus-access/40878/1 "2022-09-28T07:15:08Z")
</div>
if registers are internally updated by the CPU, and we want to monitor that cpu write activity and update the register model in parallel, How do we do it?
**Author:** ![cgales](https://verificationacademy.com/forums/letter_avatar_proxy/v4/letter/c/ccd318/32.png) [@cgales](https://verificationacademy.com/forums/u/cgales)\
**Post date:** [September 28, 2022, 12:31pm UTC](https://verificationacademy.com/forums/t/how-to-update-the-register-model-in-uvm-when-registers-gets-updated-by-the-design-internally-and-not-through-a-bus-access/40878/2 "2022-09-28T12:31:05Z")
</div>
_In reply to [sumanth291092](https://verificationacademy.com/forums/t/how-to-update-the-register-model-in-uvm-when-registers-gets-updated-by-the-design-internally-and-not-through-a-bus-access/40878):_
A register that is modified internally by the design is normally considered a read-only (RO) register. The register model will be updated when you read the register.
**Author:** ![YuankunQiu](https://verificationacademy.com/forums/letter_avatar_proxy/v4/letter/y/3e96dc/32.png) [@YuankunQiu](https://verificationacademy.com/forums/u/YuankunQiu)\
**Post date:** [October 21, 2022, 2:12am UTC](https://verificationacademy.com/forums/t/how-to-update-the-register-model-in-uvm-when-registers-gets-updated-by-the-design-internally-and-not-through-a-bus-access/40878/3 "2022-10-21T02:12:20Z")
</div>
Using the task mirror
