# How to fork multiple forever blocks with for loop
**URL:** <https://verificationacademy.com/forums/t/how-to-fork-multiple-forever-blocks-with-for-loop/36639>\
**Category:** SystemVerilog\
**Tags:** SystemVerilog, fork-join, fork-join-in-loop, forever-loopfork-join\
**Created:** [October 7, 2019, 11:09pm UTC](https://verificationacademy.com/forums/t/how-to-fork-multiple-forever-blocks-with-for-loop/36639 "2019-10-07T23:09:19Z")\
**Posts on this page:** 8\
**Page:** 1
<div class="post-metadata">
**Author:** ![NaveenReddy](https://verificationacademy.com/forums/letter_avatar_proxy/v4/letter/n/ea5d25/32.png) [@NaveenReddy](https://verificationacademy.com/forums/u/NaveenReddy)\
**Post date:** [October 7, 2019, 11:09pm UTC](https://verificationacademy.com/forums/t/how-to-fork-multiple-forever-blocks-with-for-loop/36639/1 "2019-10-07T23:09:19Z")
</div>
I want to fork multiple forever blocks using for loop. what is the best way!!
not sure if the solutions I’m trying below would work.
Thanks in advance.
```verilog
//required output
fork //fork 3 forever blocks
  forever begin
    wait(xyz[0] == 1);
    //code for loop0
  forever begin
    wait(xyz[1] == 1);
    //code for loop1
  forever begin
    wait(xyz[2] == 1);
    //code for loop2
join
//solution im thinking
// ***********want to wait till three forever blocks join**************
for(int i=0; i<3; i++) begin
    automatic int j = i;
    forever begin
      wait(xyz[j] == 1);
      //code inside task written below but explicitly written here
  join
//alternate trial - ideally I think both solutions give the same result
//just thinking forever might cause hang to the code above. So moved it into the task
    myLoop(j); //task
  join
task myLoop(int i);
  forever begin
    wait(xyz[i] == 1);
    @(posedge m_vif.uclk);
    if(!Flag[i]) begin
      wait_time[i] = getWaitTime();
      Flag[i] = 1;
    memclk_cycle[i] += 1;
    if (memclk_cycle[i] == wait_time[i]) begin
      Flag[i] = 0;
      memclk_cycle[i] = 0;
      xyz[i] = 0;
**Post date:** [October 7, 2019, 11:49pm UTC](https://verificationacademy.com/forums/t/how-to-fork-multiple-forever-blocks-with-for-loop/36639/2 "2019-10-07T23:49:48Z")
</div>
_In reply to [NaveenReddy](https://verificationacademy.com/forums/t/how-to-fork-multiple-forever-blocks-with-for-loop/36639):_
Your solution and alternate have no **fork** statements. And without knowing what kind code you intent to put in the loop, it will be hard to give a best recommendation.
**Post date:** [October 8, 2019, 3:54am UTC](https://verificationacademy.com/forums/t/how-to-fork-multiple-forever-blocks-with-for-loop/36639/3 "2019-10-08T03:54:26Z")
</div>
_In reply to [dave\_59](https://verificationacademy.com/forums/t/how-to-fork-multiple-forever-blocks-with-for-loop/36639/2):_
Hi Dave, thanks for pointing out the missing fork join. I have updated my code and the code i would be placing inside forever block.
**Post date:** [October 8, 2019, 4:23am UTC](https://verificationacademy.com/forums/t/how-to-fork-multiple-forever-blocks-with-for-loop/36639/4 "2019-10-08T04:23:53Z")
</div>
_In reply to [NaveenReddy](https://verificationacademy.com/forums/t/how-to-fork-multiple-forever-blocks-with-for-loop/36639/3):_
There really is no difference in terms of potential to hang if you put the code in a task or not.
It’s up to you to decide if using the task makes your code more readable. If this is a method of a class, putting it in a task makes it easier t override.
BTW, I recommend that you keep things synchronized by only using a clock edge and not using wait statements. Use
```verilog
    @(posedge m_vif.uclk iff xyz[i] == 1)
**Post date:** [October 8, 2019, 4:58am UTC](https://verificationacademy.com/forums/t/how-to-fork-multiple-forever-blocks-with-for-loop/36639/5 "2019-10-08T04:58:17Z")
</div>
_In reply to [dave\_59](https://verificationacademy.com/forums/t/how-to-fork-multiple-forever-blocks-with-for-loop/36639/4):_
Thanks Dave for the suggestion.
will the fork waits for all the three forever loops to join?
Also, in some post I read you suggesting to use it like below #1
what would be the best way to use #1 or #2 ?
```verilog
// #1
forever @(posedge m_vif.uclk iff xyz[i] == 1) begin
  //code
forever begin
  @(posedge m_vif.uclk iff xyz[i] == 1);
    //code
    // Question: is this way #2 correct or should the code be embedded in begin end blocks ?
**Post date:** [October 8, 2019, 5:25am UTC](https://verificationacademy.com/forums/t/how-to-fork-multiple-forever-blocks-with-for-loop/36639/6 "2019-10-08T05:25:20Z")
</div>
_In reply to [NaveenReddy](https://verificationacademy.com/forums/t/how-to-fork-multiple-forever-blocks-with-for-loop/36639/5):_
You need to use fork/join\*\_none\*. I missed that.
You can put endless number of begin/ed blocks around a single statement. I prefer to use the minimum required, but sometimes it can make the code more readable. For example
```verilog
if (cond)
  statement1;
  statement2;
statement3;
It’s not clear that only statement1 is part of the if conditional. Better to write
```verilog
if (cond) begin
  statement1;
  statement2;
statement3;
**Post date:** [October 8, 2019, 6:07am UTC](https://verificationacademy.com/forums/t/how-to-fork-multiple-forever-blocks-with-for-loop/36639/7 "2019-10-08T06:07:01Z")
</div>
_In reply to [NaveenReddy](https://verificationacademy.com/forums/t/how-to-fork-multiple-forever-blocks-with-for-loop/36639/6):_
> _In reply to [dave\_59](https://verificationacademy.com/forums/t/how-to-fork-multiple-forever-blocks-with-for-loop/36639/6):_
```verilog
// #1
//code
forever begin
//code
Dave pardon me for bugging more on this thread.
if I want the iff condition to be applied to all the below lines
will the #2 method i wrote below works?
```verilog
//#1 is straight forward since the code will be embedded in begin end blocks
//#2 but in this, the iff condition is terminated by ; and the following statements are not
// enclosed in begin end blocks. so, in that case, how would the code behave?
forever begin
  @(posedge m_vif.uclk iff xyz[i] == 1); //no begin end block here. so i believe this would only be applied to the immediate if condition here. Please correct me if I'm wrong
    if(!Flag[i]) begin
      Flag[i] = 1;
      Flag[i] = 0;
      xyz[i] = 0;
**Post date:** [October 8, 2019, 9:40pm UTC](https://verificationacademy.com/forums/t/how-to-fork-multiple-forever-blocks-with-for-loop/36639/8 "2019-10-08T21:40:11Z")
</div>
_In reply to [NaveenReddy](https://verificationacademy.com/forums/t/how-to-fork-multiple-forever-blocks-with-for-loop/36639/7):_
I think i found the answer to the question in this thread.
[https://verificationacademy.com/forums/systemverilog/what-difference-between-posedge-clk-begin-end](https://verificationacademy.com/forums/systemverilog/what-difference-between-posedge-clk-begin-end)…-and-posedge-clk
