# How to edit field name in print method
**URL:** <https://verificationacademy.com/forums/t/how-to-edit-field-name-in-print-method/32226>\
**Tags:** print-transaction, UVM, uvm\_field\_int, uvm\_printer\
**Created:** [September 4, 2016, 5:32pm UTC](https://verificationacademy.com/forums/t/how-to-edit-field-name-in-print-method/32226 "2016-09-04T17:32:40Z")\
**Showing post:** 4
**Author:** ![rakesh2learn](https://verificationacademy.com/forums/letter_avatar_proxy/v4/letter/r/9e8a1a/32.png) [@rakesh2learn](https://verificationacademy.com/forums/u/rakesh2learn)\
**Post date:** [September 6, 2016, 4:51pm UTC](https://verificationacademy.com/forums/t/how-to-edit-field-name-in-print-method/32226/4 "2016-09-06T16:51:52Z")
_In reply to [chr\_sue](https://verificationacademy.com/forums/t/how-to-edit-field-name-in-print-method/32226/3):_
My intention was to get control over editing transaction signal names in print method. In meanwhile I am checking with do\_print as suggested by cgales.
May be you could say the alternative for `uvm_field_* macros, untill the admin gives approval to my full access. Because I want to know how the transaction signals will be registered to predefined methods like print, copy, pack etc.. without using `uvm\_field\_\* macros.
_[View the full topic](https://verificationacademy.com/forums/t/how-to-edit-field-name-in-print-method/32226)._
