# How to determine the size of a multi-dimensional dynamic array in a constraint?
**URL:** <https://verificationacademy.com/forums/t/how-to-determine-the-size-of-a-multi-dimensional-dynamic-array-in-a-constraint/31948>\
**Category:** SystemVerilog\
**Tags:** multidimensional-array-systemverilog, SystemVerilog\
**Created:** [June 15, 2016, 12:32am UTC](https://verificationacademy.com/forums/t/how-to-determine-the-size-of-a-multi-dimensional-dynamic-array-in-a-constraint/31948 "2016-06-15T00:32:52Z")\
**Showing post:** 3
**Author:** ![dshanley](https://verificationacademy.com/forums/letter_avatar_proxy/v4/letter/d/f1d935/32.png) [@dshanley](https://verificationacademy.com/forums/u/dshanley)\
**Post date:** [June 15, 2016, 12:04pm UTC](https://verificationacademy.com/forums/t/how-to-determine-the-size-of-a-multi-dimensional-dynamic-array-in-a-constraint/31948/3 "2016-06-15T12:04:15Z")
_In reply to [prashant.kaushik](https://verificationacademy.com/forums/t/how-to-determine-the-size-of-a-multi-dimensional-dynamic-array-in-a-constraint/31948/2):_
Hi,
Thanks for your help, but it still doesn’t work for me.
The total\_size function always returns 0 and the solver fails.
The “solve sgl before payload\_desc;” doesn’t appear to have any effect.
If I hack the total\_size function to return, say 3. Then the solver passes as expected.
```verilog
module top;
  typedef byte sgl_t[][][16];
  // Class
  class myclass;
    rand byte sgl[][][16];
    rand byte unsigned payload[];
    rand int unsigned payload_desc[];
    // Array creation
    constraint c_sgl_size { sgl.size == 5;
                             payload.size == 15;
                             foreach(sgl[i,,]) {
                               sgl[i].size == 2;
    function int total_size(sgl_t x);
           foreach (x[i,]) begin
               total_size += x[i].size();
           return total_size;
           //return 3;
    constraint C_PAYLOAD_DISTRIBUTION {
        solve sgl before payload_desc;
        payload_desc.size == total_size(sgl);
        payload_desc.sum with (longint'(item)) == payload.size;
      $display("payload_desc size = %d ", payload_desc.size());
      $display("sgl size = %d ", sgl.size());
      foreach(sgl[i,]) begin
        $display("sgl[%1d].size= %d ", i, sgl[i].size);
      foreach(payload_desc[i]) begin
        $display("payload_desc[%1d]= %d ", i, payload_desc[i]);
    endfunction: post_randomize
  endclass // myclass
  initial
    myclass c;
    c= new();
    if(!c.randomize()) begin
      $display("Randomize fail ");
    else begin
      $display("Randomize Pass");
endmodule // top;
_[View the full topic](https://verificationacademy.com/forums/t/how-to-determine-the-size-of-a-multi-dimensional-dynamic-array-in-a-constraint/31948)._
