# How to create a parameterized class with the parameter automatically got
**URL:** <https://verificationacademy.com/forums/t/how-to-create-a-parameterized-class-with-the-parameter-automatically-got/41061>\
**Category:** UVM\
**Tags:** UVM, ParameterizedClass\
**Created:** [December 5, 2022, 7:56am UTC](https://verificationacademy.com/forums/t/how-to-create-a-parameterized-class-with-the-parameter-automatically-got/41061 "2022-12-05T07:56:55Z")\
**Posts on this page:** 7\
**Page:** 1
<div class="post-metadata">
**Author:** ![jianfeng.he](https://verificationacademy.com/forums/letter_avatar_proxy/v4/letter/j/e47774/32.png) [@jianfeng.he](https://verificationacademy.com/forums/u/jianfeng.he)\
**Post date:** [December 5, 2022, 7:56am UTC](https://verificationacademy.com/forums/t/how-to-create-a-parameterized-class-with-the-parameter-automatically-got/41061/1 "2022-12-05T07:56:55Z")
</div>
hi：
I want to create a parameterized class with the parameter automatically got by the class handle in order to make the code more flexible, so I write the code like here: [Edit code - EDA Playground](https://www.edaplayground.com/x/TxHU) , however an error occurred on line 27, So how can I implement my idea ?
thanks!
**Post date:** [December 5, 2022, 3:08pm UTC](https://verificationacademy.com/forums/t/how-to-create-a-parameterized-class-with-the-parameter-automatically-got/41061/2 "2022-12-05T15:08:08Z")
</div>
_In reply to [jianfeng.he](https://verificationacademy.com/forums/t/how-to-create-a-parameterized-class-with-the-parameter-automatically-got/41061):_
A parameter has to be constant at elaboration. In your approach this is not the case.
BTW extending your driver from uvm\_driver parameterized with the seq\_item solves your problem.
See here [(1) - EDA Playground](https://www.edaplayground.com/x/JWGp)
**Post date:** [December 5, 2022, 6:34pm UTC](https://verificationacademy.com/forums/t/how-to-create-a-parameterized-class-with-the-parameter-automatically-got/41061/3 "2022-12-05T18:34:35Z")
</div>
_In reply to [jianfeng.he](https://verificationacademy.com/forums/t/how-to-create-a-parameterized-class-with-the-parameter-automatically-got/41061/2):_
I believe you many want to use type(tr) instead of tr.get\_type(). But you need to show more examples of the flexibility you are looking for.
**Post date:** [December 6, 2022, 3:11am UTC](https://verificationacademy.com/forums/t/how-to-create-a-parameterized-class-with-the-parameter-automatically-got/41061/4 "2022-12-06T03:11:31Z")
</div>
_In reply to [dave\_59](https://verificationacademy.com/forums/t/how-to-create-a-parameterized-class-with-the-parameter-automatically-got/41061/3):_
> _In reply to [jianfeng.he](https://verificationacademy.com/forums/t/how-to-create-a-parameterized-class-with-the-parameter-automatically-got/41061/3):_
Yes, I tried type(tr) before, but it didn’t work as expected. The flexibility is that the type of drv can be determined by the type of tr I pass, code like this: [Edit code - EDA Playground](https://www.edaplayground.com/x/S5Uk)
**Post date:** [December 6, 2022, 3:20am UTC](https://verificationacademy.com/forums/t/how-to-create-a-parameterized-class-with-the-parameter-automatically-got/41061/5 "2022-12-06T03:20:41Z")
</div>
_In reply to [chr\_sue](https://verificationacademy.com/forums/t/how-to-create-a-parameterized-class-with-the-parameter-automatically-got/41061/4):_
Maybe I didn’t express my intention clearly.
Actually I want to decide which kind of drv should be instantiated by the type of tr passed, instead of instantiating a fixed drv in advance
**Post date:** [December 6, 2022, 4:02am UTC](https://verificationacademy.com/forums/t/how-to-create-a-parameterized-class-with-the-parameter-automatically-got/41061/6 "2022-12-06T04:02:30Z")
</div>
_In reply to [jianfeng.he](https://verificationacademy.com/forums/t/how-to-create-a-parameterized-class-with-the-parameter-automatically-got/41061/5):_
You can create a lookup table that associates a transaction type with a driver type. uvm\_object\_wrapper is a proxy class that serves as an object representing a uvm\_class type without actually creating an object of that type.
```verilog
uvm_object_wrapper lookup[uvm_object_wrapper];
    lookup[base_trans::get_type()] = drv#(base_trans)::get_type();
    lookup[user_def_trans::get_type()] = drv#(user_def_trans)::get_type();
    lookup[user_def_abn_trans::get_type()] = drv#(user_def_abn_trans)::get_type();
    tr0 = new;
    tr1 = new;
    tr2 = new;
    $display("--------------------");
    create_drv(tr0);
    create_drv(tr1);
    create_drv(tr2);
  function void create_drv(base_trans tr0);
    $cast(driver,lookup[tr0.get_object_type()].create_component($sformatf("drv_%0s",tr0.get_type_name()),null));
    driver.create_tr();
It’s very unusual to be creating transaction objects in the UVM’s build\_phase. You can apply this technique for create transaction proxy objects instead of transaction objects directly.
```verilog
uvm_object_wrapper tr0, tr1,tr2
    tr0 = base_trans::get_type();
    tr1 = user_def_trans::get_type();
    tr2 = user_def_abn_trans::get_type()
    create_drv(tr0);
    create_drv(tr1);
    create_drv(tr2);
  function void create_drv(uvm_object_wrapper tr0);
    $cast(driver,lookup[tr0].create_component($sformatf("drv_%0s",tr0.get_type_name()),null));
    driver.create_tr();
**Post date:** [December 6, 2022, 8:48am UTC](https://verificationacademy.com/forums/t/how-to-create-a-parameterized-class-with-the-parameter-automatically-got/41061/7 "2022-12-06T08:48:30Z")
</div>
_In reply to [dave\_59](https://verificationacademy.com/forums/t/how-to-create-a-parameterized-class-with-the-parameter-automatically-got/41061/6):_
Thank you for your help， Dave！
