# How to create a coverage range bin using the set\_covergroup\_expression option?
**URL:** <https://verificationacademy.com/forums/t/how-to-create-a-coverage-range-bin-using-the-set-covergroup-expression-option/36293>\
**Tags:** UVM, UVM-Coverage\
**Created:** [July 14, 2019, 7:46am UTC](https://verificationacademy.com/forums/t/how-to-create-a-coverage-range-bin-using-the-set-covergroup-expression-option/36293 "2019-07-14T07:46:35Z")\
**Showing post:** 8
**Post date:** [July 22, 2019, 1:28pm UTC](https://verificationacademy.com/forums/t/how-to-create-a-coverage-range-bin-using-the-set-covergroup-expression-option/36293/8 "2019-07-22T13:28:01Z")
_In reply to [snognog](https://verificationacademy.com/forums/t/how-to-create-a-coverage-range-bin-using-the-set-covergroup-expression-option/36293/7):_
Consider creating a more generic covergroup, then creating an array of covergroups iterating over your ranges.
```verilog
typedef struct {int low, high;} range_t;
range_t array[3] = { '{1,2}, '{3,5}. '{7,12} };
int value;
covergroup cg (range_t range);
  option.per_instance = 1;
  coverpoint value {
    bins b = {[range.low:range.high]};
endgroup
cg cg_h[3]
foreach (array[r]) cg[r] = new(array[r]);
_[View the full topic](https://verificationacademy.com/forums/t/how-to-create-a-coverage-range-bin-using-the-set-covergroup-expression-option/36293)._
