# How to choose a testcase class from command line on SV
**URL:** <https://verificationacademy.com/forums/t/how-to-choose-a-testcase-class-from-command-line-on-sv/31887>\
**Category:** SystemVerilog\
**Tags:** Command-Line-Processing, SystemVerilog, Polymorphism, testcase, valueplusargs\
**Created:** [June 2, 2016, 11:58am UTC](https://verificationacademy.com/forums/t/how-to-choose-a-testcase-class-from-command-line-on-sv/31887 "2016-06-02T11:58:57Z")\
**Showing post:** 2
**Post date:** [June 2, 2016, 3:09pm UTC](https://verificationacademy.com/forums/t/how-to-choose-a-testcase-class-from-command-line-on-sv/31887/2 "2016-06-02T15:09:19Z")
_In reply to [vadivelan014](https://verificationacademy.com/forums/t/how-to-choose-a-testcase-class-from-command-line-on-sv/31887):_
You can do it brute force with a case statement
```verilog
case (test_name)
"test_base" : test = new();
"test1" : test = test1::new();
"test2" : test = test2::new();
endcase
Or you can build your own factory can look-up the class by a string name in an associative array. If you want to understand how the factory works, check out my new [SystemVerilog OOP course](https://verificationacademy.com/courses/systemverilog-oop-for-uvm-verification), especially the third session.
_[View the full topic](https://verificationacademy.com/forums/t/how-to-choose-a-testcase-class-from-command-line-on-sv/31887)._
