# How to access a DUT signal from a UVM test case class?
**URL:** <https://verificationacademy.com/forums/t/how-to-access-a-dut-signal-from-a-uvm-test-case-class/29099>\
**Tags:** UVM, reference, DUT, hierarchical\
**Created:** [January 22, 2014, 7:16pm UTC](https://verificationacademy.com/forums/t/how-to-access-a-dut-signal-from-a-uvm-test-case-class/29099 "2014-01-22T19:16:29Z")\
**Showing post:** 18
**Post date:** [March 22, 2016, 10:05am UTC](https://verificationacademy.com/forums/t/how-to-access-a-dut-signal-from-a-uvm-test-case-class/29099/18 "2016-03-22T10:05:41Z")
_In reply to [Maya Sasidharan](https://verificationacademy.com/forums/t/how-to-access-a-dut-signal-from-a-uvm-test-case-class/29099/17):_
Hi Maya,
the sequence does not have a fixed place in your UVM environment. There is no hierarchical path to the UVM environment. You should call $get\_coverage from your env and stop the execution when the coverage goal is reached.
_[View the full topic](https://verificationacademy.com/forums/t/how-to-access-a-dut-signal-from-a-uvm-test-case-class/29099)._
