How do we write assumptions into a Formal Setup to create sequence which has to hit mandatorily
I’m working on a Formal for LiveLock & Deadlock. I’m using FORMAL TOOL for the same. I’m noticing none of my sequence assumption is getting picked up by the tool.
Here’s the desired sequence:e@ to trigger FSM. (i’m trying to remove/ avoid illegal values to get FSM going). I want formal engine to always drive the initial_trigger_sequence first to avoid invalid deadlocks then get into the values mentioned in the set {}. But it’s not picking up.
// 'h14231 (PAVP_SESSION) -> 'KEY_PAVP_0 -> 'KEY_PAVP_1 -> 'h14234 (PAVP_CONREQ)
// Initial sequence tracking
sequence initial_trigger_sequence;
         client_pavp.dwaddr == 'h14231 and // PAVP_SESSION
         // Wait for first fall edge of signal_ready
         ($fell(client_pavp.ready) ##2 client_pavp.dwaddr inside {'h14200, 'h14201, 'h14202, 'h14203}) and // KEY_PAVP_0
         // Next address transition after another signal_ready fall
         ($fell(client_pavp.ready) ##2 client_pavp.dwaddr inside {'h14204, 'h14205, 'h14206, 'h14207}) and // KEY_PAVP_1
         // Final address transition- PAVP_CONREQ
         ($fell(client_pavp.ready) ##2 client_pavp.dwaddr == 'h14234); endsequence
// Track the progression of addresses after signal_ready falls
rmbus_addr_assumption: assume property (
        @(posedge cdclk) disable iff (!par0_de_cdrst_b)
            initial_trigger_sequence |-> // PAVP_CONREQ
                      'h21600,
                      'h14210, 'h14211, 'h14212, 'h14213,
                      'h14214, 'h14215, 'h14216, 'h14217,
                      'h14231,
                      'h14100
This Siemens sponsored public forum is not for discussing tool specific issues. Please read your tool’s User Manual or contact your tool vendor for support.
