# How do I constrain data within hierarchy at test level?
**URL:** <https://verificationacademy.com/forums/t/how-do-i-constrain-data-within-hierarchy-at-test-level/38937>\
**Tags:** UVM, constraints\
**Created:** [April 4, 2021, 3:29am UTC](https://verificationacademy.com/forums/t/how-do-i-constrain-data-within-hierarchy-at-test-level/38937 "2021-04-04T03:29:22Z")\
**Showing post:** 3
**Post date:** [April 5, 2021, 2:06pm UTC](https://verificationacademy.com/forums/t/how-do-i-constrain-data-within-hierarchy-at-test-level/38937/3 "2021-04-05T14:06:40Z")
_In reply to [tfitz](https://verificationacademy.com/forums/t/how-do-i-constrain-data-within-hierarchy-at-test-level/38937/2):_
It is a bad approach to implement constraints in the seq\_item definition. You should contrain data memebres of the seq\_item in the sequence.
If you are using the constraints in the sequence item this constraint might conflict with constraints coming from the sequence.
_[View the full topic](https://verificationacademy.com/forums/t/how-do-i-constrain-data-within-hierarchy-at-test-level/38937)._
