# How can I test one random registers from each reg block?
**URL:** <https://verificationacademy.com/forums/t/how-can-i-test-one-random-registers-from-each-reg-block/37532>\
**Category:** UVM\
**Tags:** uvm\_ral, UVM-bitbash, UVM, uvm-ral, Cookbook-Registers\
**Created:** [May 1, 2020, 10:53pm UTC](https://verificationacademy.com/forums/t/how-can-i-test-one-random-registers-from-each-reg-block/37532 "2020-05-01T22:53:59Z")\
**Posts on this page:** 4\
**Page:** 1
<div class="post-metadata">
**Author:** ![PrashantSoni](https://verificationacademy.com/forums/letter_avatar_proxy/v4/letter/p/848f3c/32.png) [@PrashantSoni](https://verificationacademy.com/forums/u/PrashantSoni)\
**Post date:** [May 1, 2020, 10:53pm UTC](https://verificationacademy.com/forums/t/how-can-i-test-one-random-registers-from-each-reg-block/37532/1 "2020-05-01T22:53:59Z")
</div>
HI ,
I have a requirement like test random one register from each register block .
So I read cookbook and I came to know that I can test a register by using uvm\_single\_reg\_bit\_bash\_seq.
In my environment I have total 100 registers and 10 register block.
So I want to know that how can I test a random register from each register block?
Please help me .
It would be great for me If you can explain with an example.
Thanks.
**Post date:** [May 1, 2020, 11:16pm UTC](https://verificationacademy.com/forums/t/how-can-i-test-one-random-registers-from-each-reg-block/37532/2 "2020-05-01T23:16:40Z")
</div>
_In reply to [Prashant Soni](https://verificationacademy.com/forums/t/how-can-i-test-one-random-registers-from-each-reg-block/37532):_
You can get a list of registers in a block, shuffle the list, and then pick the first element.
```verilog
uvm_reg my_regs[$];
uvm_reg_single_bit_bash_seq my_seq;
my_block.get_registers(my_regs);
my_regs.shuffle();
my_seq = new($sformatf("%s_seq",my_regs[0].get_full_name());
my_seq.rg = my_regs[0];
my_seq.start()
**Post date:** [May 2, 2020, 10:06pm UTC](https://verificationacademy.com/forums/t/how-can-i-test-one-random-registers-from-each-reg-block/37532/3 "2020-05-02T22:06:03Z")
</div>
Thank you so much for your response .
I want to get each block by get\_blocks() methode but I am getting an error.
I want to pick one register from each block.
In my ral model (ral\_top\_block) there are total 10 blocks.
uvm\_reg my\_regs[]; uvm\_reg\_single\_bit\_bash\_seq my\_seq; uvm\_reg\_block my\_block[];
ral\_top\_block ral\_top;
ral\_top.get\_blocks(my\_block);
foreach(my\_block[idx])begin
ral\_top.my\_block[idx].get\_registers(my\_regs); → getting error → my\_block is not a class item
my\_regs.shuffle();
my\_seq = new($sformatf(“%s\_seq”,my\_regs[0].get\_full\_name());
my\_seq.rg = my\_regs[0];
my\_seq.start()
I can’t use my\_block variable and If I use block name like
ral\_top.ch0\_block.get\_registers(my\_regs) then Its working proparly.
But I want generic method and I don’t want to write above line 10 times .
please help me .
**Post date:** [May 3, 2020, 6:03am UTC](https://verificationacademy.com/forums/t/how-can-i-test-one-random-registers-from-each-reg-block/37532/4 "2020-05-03T06:03:14Z")
</div>
_In reply to [Prashant Soni](https://verificationacademy.com/forums/t/how-can-i-test-one-random-registers-from-each-reg-block/37532/3):_
If you have more than 1 register sub-blocks in your RAL you can get these subblocks by executing ‘get\_blocks’.
The definition is:
virtual function void get\_blocks (ref uvm\_reg\_block blks[$], input uvm\_hier\_e hier = UVM\_HIER)
and you have to execute this on your register map.
Afterwards you can extract all registers belonging to the corresponding register block by executing ‘get\_registers’.
