# How can i conditionally print display statement in assertion
**URL:** <https://verificationacademy.com/forums/t/how-can-i-conditionally-print-display-statement-in-assertion/38327>\
**Category:** SystemVerilog\
**Tags:** SVA-Assertion, SystemVerilog, display, SVA-sequence\
**Created:** [November 10, 2020, 12:37am UTC](https://verificationacademy.com/forums/t/how-can-i-conditionally-print-display-statement-in-assertion/38327 "2020-11-10T00:37:21Z")\
**Posts on this page:** 2\
**Page:** 1
<div class="post-metadata">
**Author:** ![shahparth08](https://verificationacademy.com/forums/letter_avatar_proxy/v4/letter/s/3d9bf3/32.png) [@shahparth08](https://verificationacademy.com/forums/u/shahparth08)\
**Post date:** [November 10, 2020, 12:37am UTC](https://verificationacademy.com/forums/t/how-can-i-conditionally-print-display-statement-in-assertion/38327/1 "2020-11-10T00:37:21Z")
</div>
i have a sequence which i call when an assertion is triggered to check the consequence. i have a display statement in sequence but i dont want that display statement to print everytime like the option we have with UVM\_VERBOSITY for info msgs. is there a way i can disable the display statement and only print when i set some parameter?
sequence req\_ack\_check\_seq(string property\_name,int r\_num,int a\_num,int min, int max,logic sig);
int l\_num;
(1’b1,l\_num=r\_num,**[b]$display($stime,“%0s :: Entering sequence local req\_ack counter value is %0d”,property\_name,l\_num))**_\_\__
##[min:max] ((sig==1 && a\_num==l\_num),$display($stime,“%0s :: Ack Arrived for local req\_ack counter value %0d”,property\_name,a\_num));
endsequence
**Post date:** [November 10, 2020, 12:46am UTC](https://verificationacademy.com/forums/t/how-can-i-conditionally-print-display-statement-in-assertion/38327/2 "2020-11-10T00:46:39Z")
</div>
_In reply to [shahparth08](https://verificationacademy.com/forums/t/how-can-i-conditionally-print-display-statement-in-assertion/38327):_
You can call any task or void function upon matching a sequence and that includes uvm\_report\_info (you can’t use the `uvm\_info macro directly because that expands to a block of code).
```verilog
 sequence req_ack_check_seq(string property_name,int r_num,int a_num,int min, int max,logic sig);
  int l_num;
    (1'b1,l_num=r_num,uvm_report_info("seqmatch",$sformatf("%0s :: Entering sequence local req_ack counter value is %0d",property_name,l_num)),UVM_LOW,` __FILE__ ,` __LINE__ )
      ##[min:max] ((sig==1 && a_num==l_num),$display($stime,,,"%0s :: Ack Arrived for local req_ack counter value %0d",property_name,a_num));
  endsequence
