# Getting the response of an individual sequence in virtual sequence
**URL:** <https://verificationacademy.com/forums/t/getting-the-response-of-an-individual-sequence-in-virtual-sequence/28232>\
**Category:** UVM\
**Tags:** UVM\
**Created:** [November 24, 2012, 12:17pm UTC](https://verificationacademy.com/forums/t/getting-the-response-of-an-individual-sequence-in-virtual-sequence/28232 "2012-11-24T12:17:16Z")\
**Posts on this page:** 3\
**Page:** 1
<div class="post-metadata">
**Author:** ![Jithin-vlsi](https://verificationacademy.com/forums/user_avatar/verificationacademy.com/jithin-vlsi/32/2156_2.png) [@Jithin-vlsi](https://verificationacademy.com/forums/u/Jithin-vlsi)\
**Post date:** [November 24, 2012, 12:17pm UTC](https://verificationacademy.com/forums/t/getting-the-response-of-an-individual-sequence-in-virtual-sequence/28232/1 "2012-11-24T12:17:16Z")
</div>
I have register read sequence which I am invoking in the virtual sequence.
How can I get the read data i.e. response from the driver back to reg read sequence and then to virtual sequence.
How this can be achieved without using the configuration.
Thanks in Advance
Jithin
**Author:** ![mperyer](https://verificationacademy.com/forums/letter_avatar_proxy/v4/letter/m/5f8ce5/32.png) [@mperyer](https://verificationacademy.com/forums/u/mperyer)\
**Post date:** [November 26, 2012, 10:35pm UTC](https://verificationacademy.com/forums/t/getting-the-response-of-an-individual-sequence-in-virtual-sequence/28232/2 "2012-11-26T22:35:56Z")
</div>
It’s a question of adding a data field to your register read sequence. When you get the response from the driver you assign it to the data field, then the virtual sequence can access this information from the sequence via a hierarchical reference to the data field.
The principle is outlined in:
[https://verificationacademy.com/cookbook/Sequences/Generation#Sequence\_Object\_Persistance](https://verificationacademy.com/cookbook/Sequences/Generation#Sequence_Object_Persistance)
**Post date:** [November 27, 2012, 3:34pm UTC](https://verificationacademy.com/forums/t/getting-the-response-of-an-individual-sequence-in-virtual-sequence/28232/3 "2012-11-27T15:34:49Z")
</div>
_In reply to [mperyer](https://verificationacademy.com/forums/t/getting-the-response-of-an-individual-sequence-in-virtual-sequence/28232/2):_
Thanks mperyer.
