# Get Following error Field/method name (m\_sequencer) not in 'uhdsdi\_agent\_h'
**URL:** <https://verificationacademy.com/forums/t/get-following-error-field-method-name-m-sequencer-not-in-uhdsdi-agent-h/30689>\
**Category:** UVM\
**Tags:** UVM, Cookbook-SequencesVirtualSequencer\
**Created:** [May 29, 2015, 10:37am UTC](https://verificationacademy.com/forums/t/get-following-error-field-method-name-m-sequencer-not-in-uhdsdi-agent-h/30689 "2015-05-29T10:37:59Z")\
**Posts on this page:** 2\
**Page:** 1
<div class="post-metadata">
**Author:** ![jerin1](https://verificationacademy.com/forums/letter_avatar_proxy/v4/letter/j/6de8d8/32.png) [@jerin1](https://verificationacademy.com/forums/u/jerin1)\
**Post date:** [May 29, 2015, 10:37am UTC](https://verificationacademy.com/forums/t/get-following-error-field-method-name-m-sequencer-not-in-uhdsdi-agent-h/30689/1 "2015-05-29T10:37:59Z")
</div>
I get the following error when i implemented Virstual sequencer and connect it to the Agent
Field/method name (p\_sequencer) not in ‘uhdsdi\_agent\_h’
I have the following code :
```verilog
// Virtual sequencer class:
class uhdsdi_virtual_sequencer extends uvm_virtual_sequencer;
  `uvm_component_utils(uhdsdi_virtual_sequencer)
  // give the sub-sequencers inside the virtual sequence a name
  // that respresents the interface that they are associated with,
  // this makes life easier for the test writer
  uhdsdi_sequencer tx_sqr;
  uhdsdi_rx_slv_sequencer rx_sqr;
  function new(string name = "uhdsdi_virtual_sequencer", uvm_component parent = null);
    super.new(name, parent);
endclass: uhdsdi_virtual_sequencer
and this virtual sequencer is used in env
```verilog
    uhdsdi_virtual_sequencer uhdsdi_v_sqr_h;
    endfunction: new
      uhdsdi_agent_h = uhdsdi_agent ::type_id::create("uhdsdi_agent_h", this);
      uhdsdi_subscriber_h = uhdsdi_subscriber::type_id::create("uhdsdi_subscriber_h", this);
      uhdsdi_rx_slv_agent_h = uhdsdi_rx_slv_agent ::type_id::create("uhdsdi_rx_slv_agent_h", this);
      uhdsdi_scoreboard_h = uhdsdi_scoreboard::type_id::create("uhdsdi_scoreboard_h", this);
      // Creating Virtual Sequencer
      uhdsdi_v_sqr_h = uhdsdi_virtual_sequencer::type_id::create("uhdsdi_v_sqr_h", this);
    endfunction: build_phase
      uhdsdi_agent_h.aport.connect( uhdsdi_subscriber_h.analysis_export );
      uhdsdi_agent_h.aport.connect( uhdsdi_scoreboard_h.uhdsdi_tx_export );
      uhdsdi_rx_slv_agent_h.rx_slv_aport.connect( uhdsdi_scoreboard_h.uhdsdi_rx_export );
      // Connect the Virtual Sequencer to Agent
      uhdsdi_v_sqr_h.tx_sqr = uhdsdi_agent_h.m_sequencer;
      uhdsdi_v_sqr_h.rx_sqr = uhdsdi_rx_slv_agent_h.m_sequencer;
    endfunction: connect_phase
I appreciate if somebody could tell the reason why i get this error.
**Post date:** [May 30, 2015, 5:35am UTC](https://verificationacademy.com/forums/t/get-following-error-field-method-name-m-sequencer-not-in-uhdsdi-agent-h/30689/2 "2015-05-30T05:35:31Z")
</div>
_In reply to [jerin](https://verificationacademy.com/forums/t/get-following-error-field-method-name-m-sequencer-not-in-uhdsdi-agent-h/30689):_
Can you show the line of code that is producing the error and the declaration of everything on that line?
