# Fatal: (SIGSEGV) Bad handle or reference, Error
**URL:** <https://verificationacademy.com/forums/t/fatal-sigsegv-bad-handle-or-reference-error/29336>\
**Tags:** UVM\
**Created:** [April 10, 2014, 2:18pm UTC](https://verificationacademy.com/forums/t/fatal-sigsegv-bad-handle-or-reference-error/29336 "2014-04-10T14:18:28Z")\
**Showing post:** 5
**Author:** ![Neshagar](https://verificationacademy.com/forums/letter_avatar_proxy/v4/letter/n/ba9def/32.png) [@Neshagar](https://verificationacademy.com/forums/u/Neshagar)\
**Post date:** [April 11, 2014, 11:28am UTC](https://verificationacademy.com/forums/t/fatal-sigsegv-bad-handle-or-reference-error/29336/5 "2014-04-11T11:28:53Z")
First of all, Thank you so much for advices.
But, I’ve checked my set() and get (). I could not find any fault yet… Everything seems all right. When I compile, Everything is ok even, But when I simulate. Same error again.
Here is my Test, And Config class as well:
```verilog
// --------------------------Config class
import uvm_pkg::*;
import my_pkg::*; //import our package here
`include "uvm_macros.svh"
class my_config extends uvm_object;
  `uvm_object_utils(my_config);
  virtual Exc1_if config_vif; //virtual interface to driver
  int iterations;
  function new(string name = "");
    super.new(name);
```verilog
// more information on Test class on *****VerificationAcademy Basic UVM, session 6 video******
// And Course Slide, Lecture 4
// ---------------------------------Test class (my_test1)
import uvm_pkg::*;
class my_test1 extends uvm_test; // typically we start the sequences with a Test. *** VerificationAcademy Basic Session 6 Video
    `uvm_component_utils(my_test1) // Register the test as a component
    my_env my_env_h; // the test will instantiate the Environment
    my_config m_config; // -----------------------------------------------
    my_seq seq;
    function new(string name, uvm_component parent=null);
      super.new(name, parent);
    endfunction: new
    function void set_config_params();
      m_config = my_config::type_id::create("m_config");
      if (!uvm_config_db #(virtual Exc1_if)::get(this, "","top_pif", m_config.config_vif))
        `uvm_fatal("ALU test", "Can't read the VI - config_vif");
     uvm_config_db #(my_config)::set(this, "", "my_config", m_config);
      m_config.iterations = 10;
    endfunction;
      m_config = new();
      super.build_phase(phase);
      set_report_verbosity_level_hier(UVM_MEDIUM);
      my_env_h = my_env::type_id::create("my_env_h", this);
    endfunction: build_phase
      seq = my_seq ::type_id::create("seq"); // create an instance of our "sequence", in my case "my_seq"
      phase.raise_objection(this);
      seq.start ( my_env_h.sequencer_h); // Starting the test , the argument is the sequence that will start , *** VerificationAcademy Basic session 6 Video
      phase.drop_objection(this);
  endclass: my_test1
_[View the full topic](https://verificationacademy.com/forums/t/fatal-sigsegv-bad-handle-or-reference-error/29336)._
