# Error-\[NOA\] Null object access
**URL:** <https://verificationacademy.com/forums/t/error-noa-null-object-access/40250>\
**Tags:** systemverilog-uvm, UVMF, UVM, uvm\_config\_db\
**Created:** [April 7, 2022, 1:09pm UTC](https://verificationacademy.com/forums/t/error-noa-null-object-access/40250 "2022-04-07T13:09:24Z")\
**Showing post:** 16
**Author:** ![venkatasubbarao](https://verificationacademy.com/forums/letter_avatar_proxy/v4/letter/v/a4c791/32.png) [@venkatasubbarao](https://verificationacademy.com/forums/u/venkatasubbarao)\
**Post date:** [April 7, 2022, 10:36pm UTC](https://verificationacademy.com/forums/t/error-noa-null-object-access/40250/16 "2022-04-07T22:36:46Z")
_In reply to [bob\_oden](https://verificationacademy.com/forums/t/error-noa-null-object-access/40250/15):_
I did not use the code generator, for this so is there any way I could fix this issue ? or any debugging method to fix this ?
[Click here to access code](https://www.edaplayground.com/x/eakQ)
_[View the full topic](https://verificationacademy.com/forums/t/error-noa-null-object-access/40250)._
