# Driver data not getting propagated to the DUT
**URL:** <https://verificationacademy.com/forums/t/driver-data-not-getting-propagated-to-the-dut/37543>\
**Category:** UVM\
**Tags:** UVM, UVM-DUT-connection, UVM-Driver\
**Created:** [May 5, 2020, 1:49am UTC](https://verificationacademy.com/forums/t/driver-data-not-getting-propagated-to-the-dut/37543 "2020-05-05T01:49:31Z")\
**Posts on this page:** 6\
**Page:** 1
<div class="post-metadata">
**Author:** ![Coppola](https://verificationacademy.com/forums/user_avatar/verificationacademy.com/coppola/32/2019_2.png) [@Coppola](https://verificationacademy.com/forums/u/Coppola)\
**Post date:** [May 5, 2020, 1:49am UTC](https://verificationacademy.com/forums/t/driver-data-not-getting-propagated-to-the-dut/37543/1 "2020-05-05T01:49:31Z")
</div>
I wrote this code for “Introducing Transactions” class under Basic UVM course.
I am sending some sample address, command, and data from the driver. However, DUT is not
receiving the data. I pasted most relevant SV files in my TB at the top. Please help me point to the error.
\*\*Here is the output
\*\*\_\_UVM\_INFO @ 0: reporter [RNTST] Running test my\_test…
$time = 105, addr = 0, data = 0, cmd = x
UVM\_INFO @ 200: reporter [TEST\_DONE] ‘run’ phase is ready to proceed to the ‘extract’ phase
UVM\_INFO @ 200: reporter [UVM/REPORT/CATCHER]
\*\*Here is the Code base
\*\*\_\_
DUT Interface —\> dut\_if.sv
```verilog
interface dut_if;
logic clock, reset;
logic cmd;
int data, addr;
endinterface
DUT Config File
```verilog
class dut_config extends uvm_object;
`uvm_object_utils(dut_config)
function new(string name = "dut_config");
virtual dut_if dut_vif;
DUT module —\> dut\_module.sv
```verilog
module dut(dut_if _if);
    _if.clock = 0;
    #5 _if.clock = ~_if.clock;
    #100 $display("$time = %d, addr = %d, data = %d, cmd = %d \n", $time, _if.addr, _if.data, _if.cmd);
always@(_if.data or _if.cmd or _if.addr) begin
endmodule : dut
Driver → my\_driver.svh
```verilog
class my_driver extends uvm_driver#(my_transaction);
`uvm_component_utils(my_driver)
  dut_config dut_config_0;
//virtual interface dut_if dut_vif;
    super.new(name, parent);
    super.build_phase(phase);
    if(!uvm_config_db#(dut_config)::get(this, "", "dut_config", dut_config_0))
        `uvm_fatal(get_type_name(), "Could not instantiate dut_config in my_driver")
    my_transaction tx;
    @(posedge dut_config_0.dut_vif.clock);
    seq_item_port.get_next_item(tx);
    dut_config_0.dut_vif.addr = tx.addr;
    dut_config_0.dut_vif.cmd= tx.cmd;
    dut_config_0.dut_vif.data = tx.data;
    seq_item_port.item_done();
Top Module → top.sv
```verilog
import uvm_pkg::*;
import my_pkg::*;
dut_if dut_if1();
dut dut_inst(._if(dut_if1));
initial
    uvm_config_db#(virtual dut_if)::set(null, "uvm_test_top", "dut_vif", dut_if1);
    run_test("my_test");
endmodule : top
Top level Test —\> my\_test.svh
```verilog
`uvm_component_utils(my_test)
 my_env my_env_h;
    my_env_h = my_env::type_id::create("my_env_h", this);
     dut_config_0 = new();
    if(!uvm_config_db#(virtual dut_if)::get(this, "", "dut_vif", dut_config_0.dut_vif))
        `uvm_fatal(get_type_name(), "dut_if has not been instantiated")
    uvm_config_db#(dut_config)::set(this, "*", "dut_config", dut_config_0);
    phase.raise_objection(this);
    #200;
    phase.drop_objection(this);
endclass : my_test
Env File → my\_env.svh
```verilog
class my_env extends uvm_env;
`uvm_component_utils(my_env)
my_agent my_agent_h;
    my_agent_h = my_agent::type_id::create("my_agent_h", this);
endclass : my_env
Agent → my\_agent.svh
```verilog
class my_agent extends uvm_agent;
    `uvm_component_utils(my_agent)
    my_driver my_driver_h;
    my_sequencer my_sequencer_h;
    my_monitor my_monitor_h;
        if(is_active == UVM_ACTIVE) begin
            my_driver_h = my_driver::type_id::create("my_driver_h", this);
            my_sequencer_h = my_sequencer::type_id::create("my_sequencer_h", this);
        my_monitor_h = my_monitor::type_id::create("my_monitor_h", this);
            my_driver_h.seq_item_port.connect(my_sequencer_h.seq_item_export);
Sequence —\> my\_sequence.svh
```verilog
class my_sequence extends uvm_sequence#(my_transaction);
`uvm_object_utils(my_sequence)
function new(string name = "");
    super.new(name);
task body();
    forever begin
       my_transaction tx = my_transaction::type_id::create("tx");
       start_item(tx);
       if(!tx.randomize())
           `uvm_fatal(get_type_name(), "Randomization of my_transaction instance failed")
       finish_item(tx);
Sequence Item
```verilog
class my_transaction extends uvm_sequence_item;
  `uvm_object_utils(my_transaction)
   rand bit cmd;
    rand int addr;
    rand int data;
    super.new(name);
   constraint c_addr {addr >= 0; addr <256;}
   constraint c_data {addr >= 0; addr <256;}
```verilog
typedef uvm_sequencer #(my_transaction) my_sequencer;
**Post date:** [May 5, 2020, 6:06am UTC](https://verificationacademy.com/forums/t/driver-data-not-getting-propagated-to-the-dut/37543/2 "2020-05-05T06:06:10Z")
</div>
_In reply to [Coppola](https://verificationacademy.com/forums/t/driver-data-not-getting-propagated-to-the-dut/37543):_
Would be great if you could put your example to EDAPlayground ([edaplayground.com](http://edaplayground.com)) to have an executable piece of code.
Only a few remarks:
(1) in your DUT you have your clock generator, but you generating only 1 edge.
(2) In the constructor of your config bals the constructor call to the base class is missimng. It should be
```verilog
  super.new(name);
**Post date:** [May 5, 2020, 6:22am UTC](https://verificationacademy.com/forums/t/driver-data-not-getting-propagated-to-the-dut/37543/3 "2020-05-05T06:22:31Z")
</div>
_In reply to [chr\_sue](https://verificationacademy.com/forums/t/driver-data-not-getting-propagated-to-the-dut/37543/2):_
Thanks. I was indeed missing the clock. However, even after calling base class constructor and giving clock edges, i am not seeing change in my addr, data, and cmd.
I understand my code might be too cumbersome. Will explore using EDAPlayground .
Thx!!!
$time = 5, addr = 0, data = 0, cmd = x
$time = 10, addr = 0, data = 0, cmd = x
$time = 15, addr = 0, data = 0, cmd = x
$time = 20, addr = 0, data = 0, cmd = x
$time = 25, addr = 0, data = 0, cmd = x
$time = 30, addr = 0, data = 0, cmd = x
**Post date:** [May 5, 2020, 6:31am UTC](https://verificationacademy.com/forums/t/driver-data-not-getting-propagated-to-the-dut/37543/4 "2020-05-05T06:31:10Z")
</div>
_In reply to [Coppola](https://verificationacademy.com/forums/t/driver-data-not-getting-propagated-to-the-dut/37543/3):_
Also, you never start your sequence
**Post date:** [May 5, 2020, 6:35am UTC](https://verificationacademy.com/forums/t/driver-data-not-getting-propagated-to-the-dut/37543/5 "2020-05-05T06:35:45Z")
</div>
_In reply to [Coppola](https://verificationacademy.com/forums/t/driver-data-not-getting-propagated-to-the-dut/37543/4):_
> _In reply to [chr\_sue](https://verificationacademy.com/forums/t/driver-data-not-getting-propagated-to-the-dut/37543/4):_
> Thx!!!
The data you see are the initial values of your class memebers. As Dave says you do not start the sequence. You should do this in your test.
**Post date:** [May 5, 2020, 5:33pm UTC](https://verificationacademy.com/forums/t/driver-data-not-getting-propagated-to-the-dut/37543/6 "2020-05-05T17:33:21Z")
</div>
_In reply to [chr\_sue](https://verificationacademy.com/forums/t/driver-data-not-getting-propagated-to-the-dut/37543/5):_
Thanks for the prompt replies. Once i started sequence in the test, i see the transaction flowing from driver to DUT.
```verilog
    my_sequence seq;
    seq = my_sequence::type_id::create("seq");
    seq.start(my_env_h.my_agent_h.my_sequencer_h);
    #200;
