# Distributing task calls between SV implementations in "generate" blocks
**URL:** <https://verificationacademy.com/forums/t/distributing-task-calls-between-sv-implementations-in-generate-blocks/35774>\
**Category:** SystemVerilog\
**Tags:** SystemVerilog, task, generate, distributor\
**Created:** [February 22, 2019, 1:43am UTC](https://verificationacademy.com/forums/t/distributing-task-calls-between-sv-implementations-in-generate-blocks/35774 "2019-02-22T01:43:58Z")\
**Posts on this page:** 5\
**Page:** 1
<div class="post-metadata">
**Author:** ![simonsabato](https://verificationacademy.com/forums/letter_avatar_proxy/v4/letter/s/b9e5f3/32.png) [@simonsabato](https://verificationacademy.com/forums/u/simonsabato)\
**Post date:** [February 22, 2019, 1:43am UTC](https://verificationacademy.com/forums/t/distributing-task-calls-between-sv-implementations-in-generate-blocks/35774/1 "2019-02-22T01:43:58Z")
</div>
In our “ram” library element, we compile in accessor tasks during simulation. Currently, we globally define LIB\_VENDOR or LIB\_BEHAVIORAL to control implementation. So we have code like:
```verilog
module ram;
  `ifdef LIB_VENDOR
     vendor_ram uINST ();
     task RamWrite (input a, output b);
     begin uINST.VendorRamWrite(a, b); end
  `else
     behavioral_ram uINST ();
     begin uINST.BehavioralRamWrite(a, b); end
  `endif
We use the RamWrite task to normalize the task names, arguments, etc, between the various implementations (or to print an error if the implementation doesn’t support a backdoor task).
Now we’d like to migrate to having the implementation controlled by parameter (for example, we may want to sometimes use “RTL RAM” for small memories). I was thinking that the following should work:
```verilog
module ram #(parameter Vendor = 0) ();
  generate
    if (Vendor) begin : impl_vendor
    else begin : impl_rtl
        if (Vendor) impl_vendor.uINST.VendorRamWrite(a, b);
        else impl_rtl.uINST.BehavioralRamWrite(a, b);
    endtask // RamWrite
  endgenerate
module vendor_ram;
  task VendorRamWrite (input a, output b);
    begin $display("vendor ram write"); end
  endtask // VendorRamWrite
module behavioral_ram;
  task BehavioralRamWrite (input a, output b);
    begin $display("behav ram write"); end
  endtask // BehavioralRamWrite
… But this doesn’t work. It seems that SV, for the instances, only “goes into” one of two paths, but within the ram.RamWrite task, it wants both to be there. This doesn’t seem _necessary_ … I believe I understand the classic issues of calling a task within an array of instances, etc, but in this case I thought it should work. Does this seem like a vendor-specific tool issue, and if not, what’s the “recommended” way to do this kind of thing? Note this is design-side SV code, so it would be nice to keep the verif-side complexities (UVM, classes, etc) out of it … if possible.
**Post date:** [February 22, 2019, 7:35am UTC](https://verificationacademy.com/forums/t/distributing-task-calls-between-sv-implementations-in-generate-blocks/35774/2 "2019-02-22T07:35:42Z")
</div>
_In reply to [simonsabato](https://verificationacademy.com/forums/t/distributing-task-calls-between-sv-implementations-in-generate-blocks/35774):_
SystemVerilog requires all hierarchical references to be bound at elaboration. There would have to be optimization rules to skip the binding. This might be doable at some point in the future with a generate-if construct, but more difficult with a procedural-if construct.
A suggestion for you is creating two ram module wrappers, one wrapping each implementation, and using a Verilog **config** construct to select the ram on a per instance basis. See See section 33 of 1800-2017 LRM and this paper: [https://lcdm-eng.com/papers/snug01\_verilog2000.pdf](https://lcdm-eng.com/papers/snug01_verilog2000.pdf)
**Post date:** [February 23, 2019, 3:00am UTC](https://verificationacademy.com/forums/t/distributing-task-calls-between-sv-implementations-in-generate-blocks/35774/3 "2019-02-23T03:00:51Z")
</div>
_In reply to [dave\_59](https://verificationacademy.com/forums/t/distributing-task-calls-between-sv-implementations-in-generate-blocks/35774/2):_
Thanks Dave, that was helpful. The contrast of “generate-if” vs “procedural-if” is what I was missing.
As an aside, while waiting for the response I was playing around and found that (at least on one tool) the following works:
```verilog
  generate
    else begin : impl
        if (Vendor) impl.uINST.RamWrite(a, b);
        else impl.uINST.RamWrite(a, b);
    endtask // RamWrite
  endgenerate
module vendor_ram;
Basically, name the two generate blocks the same, name the tasks the same, and ensure tasks have the same arguments. This probably doesn’t solve my original problem because I need to be able to call different subtasks.
I’m asking this followup because I’m not sure if this is expected to work (cross-vendor etc). It feels a bit like I’m “fooling” the tool. I did run it and verified that it calls the right sub-module’s task when I change the top level parameter.
If this _is_ legal, I could imagine building an additional layer of “distributor” tasks (within vendor\_ram and behavioral\_ram) which have the same name/arguments (RamWrite), which then call the local versions (VendorRamWrite & BehavioralRamWrite). If that is somehow valid it’s another way to get this to work.
I’ll still look into the config files. AFAIK those are the only way to swap in a _really_ different implementation (behavioral, gate level, etc) so it’s a powerful technique. It’s not ideal for the problem I was trying to solve as I’m trying to make a very reusable library and I don’t want the “integration” person to be in the loop for these RAM mappings. If the config file can be setup hierarchically that could work…
**Post date:** [February 23, 2019, 6:42am UTC](https://verificationacademy.com/forums/t/distributing-task-calls-between-sv-implementations-in-generate-blocks/35774/4 "2019-02-23T06:42:01Z")
</div>
_In reply to [simonsabato](https://verificationacademy.com/forums/t/distributing-task-calls-between-sv-implementations-in-generate-blocks/35774/3):_
Yes, what you wrote is legal. I think _Example 4_ in LRM section 27.5 is very similar to what you are doing.
And yes, you can build up config declarations hierarchically.
**Post date:** [February 27, 2019, 7:47pm UTC](https://verificationacademy.com/forums/t/distributing-task-calls-between-sv-implementations-in-generate-blocks/35774/5 "2019-02-27T19:47:11Z")
</div>
_In reply to [dave\_59](https://verificationacademy.com/forums/t/distributing-task-calls-between-sv-implementations-in-generate-blocks/35774/4):_
Dave,
THANKS!
That was exactly the shove that I needed. The following code shows a working solution to the original question. It _does_ use a layer of “distributor” tasks. But since the “distribution layer” is within the wrapper, it _doesn’t_ require modifying the vendor\_ram / behavioral\_ram implementations, which is key (they may be 3rd party, encrypted etc).
Specifically the two things I was missing:
- LRM 27.5 discussion on how multiple generate blocks can use the same name if only one will be included
- Putting tasks within the conditional generate blocks (next to the RAM instances) allows for a unique task for each possible implementation, all having the same name/args, such that the top level RamWrite task can just call impl.RamWrite unconditionally.
```verilog
  generate
      endtask // RamWrite
    else begin : impl
        uINST.BehavioralRamWrite(a, b, 0, 1);
      endtask // RamWrite
      impl.RamWrite(a, b);
    endtask // RamWrite
  endgenerate
module vendor_ram;
  task BehavioralRamWrite (input a, output b, input x, input y);
