# Constraint Question
**URL:** <https://verificationacademy.com/forums/t/constraint-question/35507>\
**Category:** UVM\
**Tags:** UVM\
**Created:** [December 24, 2018, 8:02am UTC](https://verificationacademy.com/forums/t/constraint-question/35507 "2018-12-24T08:02:58Z")\
**Posts on this page:** 4\
**Page:** 1
<div class="post-metadata">
**Author:** ![kmishra](https://verificationacademy.com/forums/letter_avatar_proxy/v4/letter/k/f19dbf/32.png) [@kmishra](https://verificationacademy.com/forums/u/kmishra)\
**Post date:** [December 24, 2018, 8:02am UTC](https://verificationacademy.com/forums/t/constraint-question/35507/1 "2018-12-24T08:02:58Z")
</div>
How to write constraint, where A will be divisible by 6 and it it’s true, then B should be nearest to A.
**Post date:** [December 24, 2018, 8:23am UTC](https://verificationacademy.com/forums/t/constraint-question/35507/2 "2018-12-24T08:23:02Z")
</div>
_In reply to [kmishra](https://verificationacademy.com/forums/t/constraint-question/35507):_
Here is most of your constrain, except I don’t know what “B should be nearest to A” means.
```verilog
(A % 6) ==0 -> (????)
Can you give some examples of values you are looking for that meet your constraint?
**Author:** ![jjuxec](https://verificationacademy.com/forums/letter_avatar_proxy/v4/letter/j/a6a055/32.png) [@jjuxec](https://verificationacademy.com/forums/u/jjuxec)\
**Post date:** [December 24, 2018, 11:45am UTC](https://verificationacademy.com/forums/t/constraint-question/35507/3 "2018-12-24T11:45:22Z")
</div>
_In reply to [kmishra](https://verificationacademy.com/forums/t/constraint-question/35507/2):_
From the statement which is “nearest”, I guess that you have another variable(s) other than A and B. The case you state says that B must be nearest to A, so if we assume that you have a sequence item which is named as “dummy\_seq\_item”, you can write sth like this:
--------------Your seq\_item code-------------------
class dummy\_seq\_item extends uvm\_sequence\_item;
`uvm\_object\_utils(dummy\_seq\_item)
function new(string name=“dummy\_seq\_item”);
super.new(name);
rand int A;
rand int B;
rand int C;
constraint A\_is\_first{
solve A before B;
solve A before C;
constraint which\_is\_closer{
((A%6) == 0 ) → ( B\>C );
let’s say, if you have D, E and etc. other than B and C, you can write a swap function instead of right hand side of the constraint. If it returns 1, constraint will be valid.
**Post date:** [December 28, 2018, 6:32am UTC](https://verificationacademy.com/forums/t/constraint-question/35507/4 "2018-12-28T06:32:16Z")
</div>
_In reply to [yuksek](https://verificationacademy.com/forums/t/constraint-question/35507/3):_
> _In reply to [kmishra](https://verificationacademy.com/forums/t/constraint-question/35507/3):_
> super.new(name);
> endfunction
> rand int A;
> rand int B;
> rand int C;
> solve A before B;
> solve A before C;
> endclass
Thanks for the suggestions, got some idea now.
