# Constraint involving queues and arrays
**URL:** <https://verificationacademy.com/forums/t/constraint-involving-queues-and-arrays/35998>\
**Category:** SystemVerilog\
**Tags:** SystemVerilog, constraints\
**Created:** [April 20, 2019, 4:28am UTC](https://verificationacademy.com/forums/t/constraint-involving-queues-and-arrays/35998 "2019-04-20T04:28:27Z")\
**Posts on this page:** 10\
**Page:** 1
<div class="post-metadata">
**Author:** ![atalur](https://verificationacademy.com/forums/letter_avatar_proxy/v4/letter/a/f19dbf/32.png) [@atalur](https://verificationacademy.com/forums/u/atalur)\
**Post date:** [April 20, 2019, 4:28am UTC](https://verificationacademy.com/forums/t/constraint-involving-queues-and-arrays/35998/1 "2019-04-20T04:28:27Z")
</div>
The code is like below -
```verilog
module test();
class temp;
  int array[15] = {1,2,3,4,5,6,7,8,9,10,11,12,13,14,8};
  rand int q1[$];
  rand int q2[$];
  rand int q3[$];
  constraint c1 {
    q1.size == 5;
    q2.size == 5;
    q3.size == 5;
    foreach (q1[i]) {
      q1[i] inside {array};
      q2[i] inside {array};
      q3[i] inside {array};
    unique {q1,q2};
    unique {q2,q3};
    unique {q3};
initial
      temp t = new();
      t.randomize();
      $display ("%p\n %p\n %p\n", t.q1, t.q2, t.q3);
      $finish;
The current output looks like so -
'{10, 6, 11, 1, 13}
'{4, 2, 5, 3, 12}
'{11, 13, 10, 14, 8}
q1, q2 and q3 are all required to contains elements from array. No element should be shared across q1,q2,q3 unless the element is repeated in the array itself in which case it is fine.
I got as far as getting 2/3 queues unique but q3 would always have elements from q1 or q2. How can I constrain q3 to be '{7, 8, 8, 9, 14} which is all the remaining elements of array not in both q1 and q2.
EDIT: I could do it in post\_randomize but is there a way through constraints
**Post date:** [April 21, 2019, 4:44pm UTC](https://verificationacademy.com/forums/t/constraint-involving-queues-and-arrays/35998/2 "2019-04-21T16:44:07Z")
</div>
_In reply to [kernalmode1](https://verificationacademy.com/forums/t/constraint-involving-queues-and-arrays/35998):_
What you want is to pick elements of a list, and its the index into the list that needs to be unique. You can extrapolate this to get your three q’s.
```verilog
module test();
class temp;
   rand int idx[15];
   rand int q[15];
   constraint c1 {
      foreach (q[i]) {
	 idx[i] inside {[0:14]};
	 q[i] == array[idx[i]];
      unique {idx};
   initial
	static temp t = new();
	assert(t.randomize());
	$display ("%p\n %p ", t.idx, t.q);
	$finish;
**Post date:** [April 21, 2019, 10:08pm UTC](https://verificationacademy.com/forums/t/constraint-involving-queues-and-arrays/35998/3 "2019-04-21T22:08:49Z")
</div>
_In reply to [dave\_59](https://verificationacademy.com/forums/t/constraint-involving-queues-and-arrays/35998/2):_
Thank you Dave. Really appreciate you opening my thoughts to this approach.
**Author:** ![UVM\_learner6](https://verificationacademy.com/forums/letter_avatar_proxy/v4/letter/u/a8b319/32.png) [@UVM\_learner6](https://verificationacademy.com/forums/u/UVM_learner6)\
**Post date:** [October 25, 2019, 6:19am UTC](https://verificationacademy.com/forums/t/constraint-involving-queues-and-arrays/35998/4 "2019-10-25T06:19:40Z")
</div>
_In reply to [kernalmode1](https://verificationacademy.com/forums/t/constraint-involving-queues-and-arrays/35998/3):_
```verilog
module test();
class temp;
rand int q1[$];
rand int q2[$];
rand int q3[$];
constraint c1 {
q1.size == 5;
q2.size == 5;
q3.size == 5;
foreach (q1[i]) {
unique {q1,q2};
unique {q2,q3};
unique {q3};
initial
temp t = new();
t.randomize();
$finish;
'{10, 6, 11, 1, 13}
'{4, 2, 5, 3, 12}
Hi, Would you be able to show how you got the 3rd queue to be unique elements in post\_randomize?
Thanks.
**Author:** ![iamyash1234](https://verificationacademy.com/forums/letter_avatar_proxy/v4/letter/i/67e7ee/32.png) [@iamyash1234](https://verificationacademy.com/forums/u/iamyash1234)\
**Post date:** [November 10, 2021, 9:43am UTC](https://verificationacademy.com/forums/t/constraint-involving-queues-and-arrays/35998/5 "2021-11-10T09:43:59Z")
</div>
_In reply to [kernalmode1](https://verificationacademy.com/forums/t/constraint-involving-queues-and-arrays/35998/4):_
How you can do that using post randomize can u explain please.
**Post date:** [November 10, 2021, 9:38pm UTC](https://verificationacademy.com/forums/t/constraint-involving-queues-and-arrays/35998/6 "2021-11-10T21:38:51Z")
</div>
_In reply to [Yash\_wanth12345](https://verificationacademy.com/forums/t/constraint-involving-queues-and-arrays/35998/5):_
```verilog
class temp;
  int q1[$];
  int q2[$];
  int q3[$];
   array.shuffle();
   q1 = array[0:4];
   q2 = array[5:9];
   q3 = array[10:14];
**Author:** ![ABD\_91](https://verificationacademy.com/forums/letter_avatar_proxy/v4/letter/a/c77e96/32.png) [@ABD\_91](https://verificationacademy.com/forums/u/ABD_91)\
**Post date:** [November 19, 2021, 10:33am UTC](https://verificationacademy.com/forums/t/constraint-involving-queues-and-arrays/35998/7 "2021-11-19T10:33:11Z")
</div>
_In reply to [dave\_59](https://verificationacademy.com/forums/t/constraint-involving-queues-and-arrays/35998/6):_
Based on [Random\_Variables\_as\_index](https://verificationacademy.com/forums/systemverilog/random-variables-indexes-constraints) , **isn’t the following Syntax Illegal as per LRM ??** ::
```verilog
  q[i] == array[idx[i]] ;
**Is there an alternate solution ( without post\_randomize() ) ??**
**Post date:** [November 19, 2021, 7:51pm UTC](https://verificationacademy.com/forums/t/constraint-involving-queues-and-arrays/35998/8 "2021-11-19T19:51:42Z")
</div>
_In reply to [ABD\_91](https://verificationacademy.com/forums/t/constraint-involving-queues-and-arrays/35998/7):_
It’s all legal syntax. The current LRM has a semantic restriction not allowing a random index selecting parts of a random variable. In the example above, **array** is a state variable and **i** is an iterative loop variable.
**Author:** ![sk7799](https://verificationacademy.com/forums/letter_avatar_proxy/v4/letter/s/b487fb/32.png) [@sk7799](https://verificationacademy.com/forums/u/sk7799)\
**Post date:** [February 13, 2023, 9:05pm UTC](https://verificationacademy.com/forums/t/constraint-involving-queues-and-arrays/35998/9 "2023-02-13T21:05:26Z")
</div>
_In reply to [dave\_59](https://verificationacademy.com/forums/t/constraint-involving-queues-and-arrays/35998/8):_
Can you please explain why you took 2 separate arrays as shown below.
rand int idx[15];
rand int q[15];
Can you also please explain what this means : q[i] == array[idx[i]];
Thanks in advance.
I am unable to understand why unique{q3} is not working in the above code.
**Author:** ![Blitzz0418](https://verificationacademy.com/forums/letter_avatar_proxy/v4/letter/b/8c91f0/32.png) [@Blitzz0418](https://verificationacademy.com/forums/u/Blitzz0418)\
**Post date:** [February 13, 2023, 10:57pm UTC](https://verificationacademy.com/forums/t/constraint-involving-queues-and-arrays/35998/10 "2023-02-13T22:57:10Z")
</div>
_In reply to [sk7799](https://verificationacademy.com/forums/t/constraint-involving-queues-and-arrays/35998/9):_
idx array will have unique values from 0-14 and then this unique values are used to index into the array to assign it to queues.
idx[i] - will have unique value
array[idx[i]] - in turn will have unique value
