# Constraint existence of value into an array
**URL:** <https://verificationacademy.com/forums/t/constraint-existence-of-value-into-an-array/39284>\
**Category:** SystemVerilog\
**Tags:** SystemVerilog, constraint, randomization, array-methods, arrays\
**Created:** [July 8, 2021, 3:04am UTC](https://verificationacademy.com/forums/t/constraint-existence-of-value-into-an-array/39284 "2021-07-08T03:04:40Z")\
**Showing post:** 4
**Post date:** [July 8, 2021, 7:05am UTC](https://verificationacademy.com/forums/t/constraint-existence-of-value-into-an-array/39284/4 "2021-07-08T07:05:56Z")
_In reply to [nimrodw](https://verificationacademy.com/forums/t/constraint-existence-of-value-into-an-array/39284/3):_
You cannot have expressions containing unpacked arrays unless you use a foreach loop or a reduction method.
```verilog
class some_object extends uvm_object;
  rand bit [1:0] arr[6];
  constraint the_constraint_c{
    arr.sum() with {int'(item==1)) == 1;
    arr.sum() with {int'(item==2)) == 1;
    arr.sum() with {int'(item==3)) == 1;
function new(string name = "some_object");
  super.new(name);
endclass: some_object
I am constraining the sum of the number of times each elements equals 1,2, or 3 to be 1.
_[View the full topic](https://verificationacademy.com/forums/t/constraint-existence-of-value-into-an-array/39284)._
