# Connection between Reference Model and Scoreboard
**URL:** <https://verificationacademy.com/forums/t/connection-between-reference-model-and-scoreboard/41831>\
**Tags:** UVM, reference-model, scoreboard\
**Created:** [June 17, 2023, 8:29pm UTC](https://verificationacademy.com/forums/t/connection-between-reference-model-and-scoreboard/41831 "2023-06-17T20:29:25Z")\
**Showing post:** 3
**Author:** ![Yeptho](https://verificationacademy.com/forums/letter_avatar_proxy/v4/letter/y/779978/32.png) [@Yeptho](https://verificationacademy.com/forums/u/Yeptho)\
**Post date:** [June 19, 2023, 4:55am UTC](https://verificationacademy.com/forums/t/connection-between-reference-model-and-scoreboard/41831/3 "2023-06-19T04:55:02Z")
_In reply to [dave\_59](https://verificationacademy.com/forums/t/connection-between-reference-model-and-scoreboard/41831/2):_
Thank you dave.
by the way, indeed my reference model is a class based and it is extended from uvm\_component.
I presume your statement “component inside the scoreboard” meaning instantiate reference model inside the scoreboard where Hierarchal wise scoreboard will be the parent for reference class?
If that is so, from the scoreboard write function, do I need to feed inputs data to reference model?
_[View the full topic](https://verificationacademy.com/forums/t/connection-between-reference-model-and-scoreboard/41831)._
