# Config\_db set/get is not working properly
**URL:** <https://verificationacademy.com/forums/t/config-db-set-get-is-not-working-properly/30668>\
**Tags:** UVM, config\_db, get\_config\_object, factory, set\_config\_\
**Created:** [May 22, 2015, 11:42am UTC](https://verificationacademy.com/forums/t/config-db-set-get-is-not-working-properly/30668 "2015-05-22T11:42:25Z")\
**Showing post:** 3
**Author:** ![sivasyammj](https://verificationacademy.com/forums/letter_avatar_proxy/v4/letter/s/a87d85/32.png) [@sivasyammj](https://verificationacademy.com/forums/u/sivasyammj)\
**Post date:** [May 22, 2015, 1:08pm UTC](https://verificationacademy.com/forums/t/config-db-set-get-is-not-working-properly/30668/3 "2015-05-22T13:08:23Z")
_In reply to [cgales](https://verificationacademy.com/forums/t/config-db-set-get-is-not-working-properly/30668/2):_
Hi cgales,
while using the get we can use either Null or this.
any way i tried both this is not working on both scenarios
-sivajsyamm
_[View the full topic](https://verificationacademy.com/forums/t/config-db-set-get-is-not-working-properly/30668)._
