# Config\_db::set from Same Level of Hierarchy
**URL:** <https://verificationacademy.com/forums/t/config-db-set-from-same-level-of-hierarchy/37740>\
**Category:** UVM\
**Tags:** UVM, config\_dbset-from-Same-Level-of-Hierarchy\
**Created:** [June 20, 2020, 8:48pm UTC](https://verificationacademy.com/forums/t/config-db-set-from-same-level-of-hierarchy/37740 "2020-06-20T20:48:48Z")\
**Posts on this page:** 3\
**Page:** 1
<div class="post-metadata">
**Author:** ![MICRO\_91](https://verificationacademy.com/forums/letter_avatar_proxy/v4/letter/m/5f9b8f/32.png) [@MICRO\_91](https://verificationacademy.com/forums/u/MICRO_91)\
**Post date:** [June 20, 2020, 8:48pm UTC](https://verificationacademy.com/forums/t/config-db-set-from-same-level-of-hierarchy/37740/1 "2020-06-20T20:48:48Z")
</div>
Hi all ,
I am trying so set “is\_active” variable ( of class uvm\_agent ) from 2 Components at Same level of Hierarchy
```verilog
`include "uvm_pkg.sv"
`include "uvm_macros.svh"
import uvm_pkg::*;
`define COMP_NEW function new ( string name , uvm_component parent ) ; \
                  super.new(name,parent);\
 class agent extends uvm_agent ;
 `uvm_component_utils( agent )
 `COMP_NEW
function void build_phase ( uvm_phase phase ) ;
 int active;
  `uvm_info(get_name(),"In build_phase",UVM_NONE)
  if( get_config_int("is_active", active) )
    `uvm_info(get_name()," get_config_int is Successful !! ",UVM_NONE)
     is_active = uvm_active_passive_enum'(active);
 class test extends uvm_component ;
 `uvm_component_utils( test )
 `COMP_NEW
  agent ag ;
    uvm_config_db#(int)::set(this,"*","is_active",101) ; // Value of 101 set from Test i.e Active ( Since LSB is 1 ) !!
	 ag = new("ag",this) ;
  function void end_of_elaboration_phase ( uvm_phase phase ) ;
     uvm_top.print_topology();
 class my_class extends uvm_component ;
 `uvm_component_utils( my_class )
 `COMP_NEW
	uvm_config_db#(int)::set(uvm_top,"*","is_active",100) ; // Value of 100 set i.e Passive ( Since LSB is 0 ) !! !!
my_class class_h ;
   class_h = new("class_h",null);
   run_test("test") ;
Since “class\_h” and uvm\_test\_top i.e test are AT SAME LEVEL OF HIERARCHY , I expected get\_config\_int to be successful with is\_active set to UVM\_ACTIVE.
**But I notice that in Output get() isn’t successful**
**Any thoughts ?**
Thanks in advance
**Post date:** [June 20, 2020, 11:07pm UTC](https://verificationacademy.com/forums/t/config-db-set-from-same-level-of-hierarchy/37740/2 "2020-06-20T23:07:48Z")
</div>
_In reply to [MICRO\_91](https://verificationacademy.com/forums/t/config-db-set-from-same-level-of-hierarchy/37740):_
See [Usage of set\_config\_\* methods on global scope | Verification Academy](https://verificationacademy.com/forums/uvm/usage-setconfig-methods-global-scope#reply-40256)
**Post date:** [June 21, 2020, 4:08pm UTC](https://verificationacademy.com/forums/t/config-db-set-from-same-level-of-hierarchy/37740/3 "2020-06-21T16:08:25Z")
</div>
_In reply to [dave\_59](https://verificationacademy.com/forums/t/config-db-set-from-same-level-of-hierarchy/37740/2):_
Since the **type-parameter is different** the get() doesn’t succeed .
Thanks , Dave
