# Clock Frequency Check ( considering Jitter )
**URL:** <https://verificationacademy.com/forums/t/clock-frequency-check-considering-jitter/40263>\
**Category:** SystemVerilog\
**Tags:** SystemVerilog, Clock-Frequency-Check--considering-Jitter-\
**Created:** [April 11, 2022, 6:53pm UTC](https://verificationacademy.com/forums/t/clock-frequency-check-considering-jitter/40263 "2022-04-11T18:53:32Z")\
**Showing post:** 5
**Author:** ![hisingh](https://verificationacademy.com/forums/letter_avatar_proxy/v4/letter/h/97f17d/32.png) [@hisingh](https://verificationacademy.com/forums/u/hisingh)\
**Post date:** [April 13, 2022, 12:44am UTC](https://verificationacademy.com/forums/t/clock-frequency-check-considering-jitter/40263/5 "2022-04-13T00:44:54Z")
_In reply to [dave\_59](https://verificationacademy.com/forums/t/clock-frequency-check-considering-jitter/40263/4):_
For the duty cycle related assertion , similar to the solution to the original question I could use a time literal ::
```verilog
 // Duty Cycle Must be 55.555 % +- 0.05 % for 1MHz Clock
         assert property( clock_frequency( 555.55ns , 0.05 * ( 555.55ns ) )
But using a time literal restricts the usage of a generic property .
**If the clock period is unknown ( hence can’t use a time literal to the argument(s) ) and I simply want to check the duty cycle , is there any alternative ?**
_[View the full topic](https://verificationacademy.com/forums/t/clock-frequency-check-considering-jitter/40263)._
