# Check one register in each block using RAL
**URL:** <https://verificationacademy.com/forums/t/check-one-register-in-each-block-using-ral/38777>\
**Category:** UVM\
**Tags:** UVM, UVM-RAL-systemverilog-ralmodelling\
**Created:** [March 4, 2021, 12:05am UTC](https://verificationacademy.com/forums/t/check-one-register-in-each-block-using-ral/38777 "2021-03-04T00:05:15Z")\
**Posts on this page:** 2\
**Page:** 1
<div class="post-metadata">
**Author:** ![kesav\_abj](https://verificationacademy.com/forums/letter_avatar_proxy/v4/letter/k/7ea924/32.png) [@kesav\_abj](https://verificationacademy.com/forums/u/kesav_abj)\
**Post date:** [March 4, 2021, 12:05am UTC](https://verificationacademy.com/forums/t/check-one-register-in-each-block-using-ral/38777/1 "2021-03-04T00:05:15Z")
</div>
I need to check one register in a block ,
I coded as below
```verilog
class x_sequnece extends uvm_sequence
uvm_reg blk_reg[$];
task x_sequence :: do_sequence()
 uvm_reg_block all_reg_blocks[$];
for (block[i])begin
uvm_reg_single_bit_bash_req bit_reg;
block[i].get_registers(blk_req)
bit_reg = uvm_reg_single_bit_bash_seq::type_id::create("bit_req");
bit_req.rg = blk_reg[0];
bit_reg.start()
Please let me know if this would work
**Post date:** [March 4, 2021, 7:07pm UTC](https://verificationacademy.com/forums/t/check-one-register-in-each-block-using-ral/38777/2 "2021-03-04T19:07:59Z")
</div>
_In reply to [kesav\_abj](https://verificationacademy.com/forums/t/check-one-register-in-each-block-using-ral/38777):_
This will not work for 2 reasons:
(1) a sequence needs a body task.
(2) you have to start your sequence on a sequencer.
