# Change mirror value of a register field before running uvm\_reg\_hw\_reset\_seq
**URL:** <https://verificationacademy.com/forums/t/change-mirror-value-of-a-register-field-before-running-uvm-reg-hw-reset-seq/33567>\
**Tags:** UVM, predict, uvm\_reg\_hw\_reset\_seq, get\_mirrored\_value\
**Created:** [October 5, 2017, 2:11pm UTC](https://verificationacademy.com/forums/t/change-mirror-value-of-a-register-field-before-running-uvm-reg-hw-reset-seq/33567 "2017-10-05T14:11:04Z")\
**Showing post:** 9
**Author:** ![tejastv](https://verificationacademy.com/forums/letter_avatar_proxy/v4/letter/t/bbe5ce/32.png) [@tejastv](https://verificationacademy.com/forums/u/tejastv)\
**Post date:** [October 9, 2017, 9:11am UTC](https://verificationacademy.com/forums/t/change-mirror-value-of-a-register-field-before-running-uvm-reg-hw-reset-seq/33567/9 "2017-10-09T09:11:29Z")
_In reply to [birenkumar](https://verificationacademy.com/forums/t/change-mirror-value-of-a-register-field-before-running-uvm-reg-hw-reset-seq/33567/8):_
Below hack can help you,
```verilog
class customized_uvm_reg_hw_reset_seq extends uvm_reg_sequence #(uvm_sequence #(uvm_reg_item));
  // Subset of maps to be considered for running this sequence
  string test_on_maps[$];
  bit [31:0] register_addr;
  reg_test_splitter m_reg_split_h;
  bit model_should_not_be_reset;
  bit predict_retention;
  int retention_value;
  `uvm_object_utils(customized_uvm_reg_hw_reset_seq)
  function new(string name="customized_uvm_reg_hw_reset_seq");
    super.new(name);
    m_reg_split_h = reg_test_splitter::type_id::create("m_reg_split_h");
  virtual task body();
    uvm_reg regs[$];
    uvm_reg_map maps[$];
    string map_name;
    if (model == null)
      `uvm_error("customized_uvm_reg_hw_reset_seq", "Not block or system specified to run sequence on");
      return;
    m_reg_split_h.get_configs();
    uvm_report_info("STARTING_SEQ",{"\n\nStarting ",get_name()," sequence...\n"},UVM_LOW);
    if (uvm_resource_db#(bit)::get_by_name({"REG::",model.get_full_name()},
      "NO_REG_TESTS", 0) != null ||
      "NO_REG_HW_RESET_TEST", 0) != null )
    return;
    // Hack for specific model to be reset/not
    if(!model_should_not_be_reset)
      `uvm_info("RESETTING_REG_MODEL",get_name(),UVM_LOW)
      this.reset_blk(model);
      model.reset();
    else
      `uvm_info("NOT_RESETTING_REG_MODEL",get_name(),UVM_LOW)
      model.get_maps(maps);
    // Iterate over all maps defined for the RegModel block
    foreach (maps[d])
      map_name = maps[d].get_name();
      foreach(test_on_maps[i])
	if (map_name == test_on_maps[i])
          uvm_status_e status;
	  regs.delete();
	  maps[d].get_registers(regs);
          if (regs.size() == 0)
            `uvm_fatal("customized_uvm_reg_hw_reset_seq", "Did not find any registers to test")
            return;
          m_reg_split_h.filter(regs);
          foreach (regs[i])
          begin :foreach_loop
            uvm_reg my_reg = regs[i];
            register_addr = regs[i].get_address();
            // Registers with certain attributes are not to be tested
            if (uvm_resource_db#(bit)::get_by_name({"REG::",regs[i].get_full_name()},
	      continue;
            // Simpl hack to load the mirror value apart from reset value
            if(predict_retention && regs[i].get_name() == "RETENTION_REGISTER")
	       regs[i].predict(retention_value);
            // Regular mirror method
	    regs[i].mirror(status, UVM_CHECK, UVM_FRONTDOOR, maps[d], this);
            if (status != UVM_IS_OK)
            begin : uvm_okay
              `uvm_error(get_type_name(),
	      $sformatf("Status was %s when reading reset value of register \"%s\" through map \"%s\".",
	      status.name(), regs[i].get_full_name(), maps[d].get_full_name()));
	    end : uvm_okay
          end :foreach_loop
  endtask: body
endclass: customized_uvm_reg_hw_reset_seq
_[View the full topic](https://verificationacademy.com/forums/t/change-mirror-value-of-a-register-field-before-running-uvm-reg-hw-reset-seq/33567)._
