# Best method to write sequences
**URL:** <https://verificationacademy.com/forums/t/best-method-to-write-sequences/33630>\
**Category:** UVM\
**Tags:** Cookbook-SequencesHierarchy, UVM\
**Created:** [October 19, 2017, 12:20pm UTC](https://verificationacademy.com/forums/t/best-method-to-write-sequences/33630 "2017-10-19T12:20:56Z")\
**Posts on this page:** 2\
**Page:** 1
<div class="post-metadata">
**Author:** ![PK](https://verificationacademy.com/forums/letter_avatar_proxy/v4/letter/p/bbce88/32.png) [@PK](https://verificationacademy.com/forums/u/PK)\
**Post date:** [October 19, 2017, 12:20pm UTC](https://verificationacademy.com/forums/t/best-method-to-write-sequences/33630/1 "2017-10-19T12:20:56Z")
</div>
I am verifying Bluetooth 5.0 and I would like to know the best method of writing layered sequences keeping controllability and reusability in mind.
FIRST APPROACH:
There is a virtual sequence which I haven’t shown here and the mid level\_1 sequence is as follows:
```auto
class ble_set_adv_ext_parameters extends uvm_sequence;
	task body();
		set_conn_idx_seq.start(m_sequencer,this);
		set_adv_param_seq.start(m_sequencer,this);
The mid level\_2 sequence is as follows:
```auto
class ble_set_connection_index_sequence extends uvm_sequence;
	task body();
		ble_ahb_sing_wrt_seq = ble_ahb_single_write_sequence :: type_id :: create("ble_ahb_sing_wrt_seq");
		ble_ahb_sing_wrt_seq.write(32'h0 , 16'h0,m_sequencer,this);
Then there is a bottom level sequence :
```auto
class ble_ahb_single_write_sequence extends uvm_sequence #(ble_ahb_sequence_item);
	extern task body();
	extern task write(input bit [31:0] haddr, input bit[15:0] hwdata,input uvm_sequencer_base seqr,input uvm_sequence_base parent = null);
task ble_ahb_single_write_sequence :: body();
	start_item(ble_ahb_seq_item);
		assert (ble_ahb_seq_item.randomize() with {
                                                            ble_ahb_seq_item.haddr == local :: haddr;
						            ble_ahb_seq_item.hwdata == local :: hwdata;
							    ble_ahb_seq_item.hwrite == 1;
							    ble_ahb_seq_item.hsel == 1;
							    ble_ahb_seq_item.hburst == 3'b000;
	finish_item(ble_ahb_seq_item);
	`uvm_info("AHB_Single_Write_Sequence", "Exiting Slave Sequence", UVM_LOW)
task ble_ahb_single_write_sequence :: write (input bit [31:0] haddr, input bit[15:0] hwdata,input uvm_sequencer_base seqr,input uvm_sequence_base parent = null);
	this.haddr = haddr;
	this.hwdata = hwdata;
	this.start(seqr,parent);
SECOND APPROACH:
In this approach, the mid\_level sequence is not sub-divided
```auto
	task body();
		ble_ahb_sing_wrt_seq.write(32'h5 , 16'h456,m_sequencer,this);
If I want to change the data written into the registers, and if I follow the first approach, I can override only the required mid\_level\_2 sequence without changing the mid\_level\_1 sequence. However if I use the second approach, If I want to change the written data, I have to use a new mid\_level\_1 sequence.
**Post date:** [October 19, 2017, 12:57pm UTC](https://verificationacademy.com/forums/t/best-method-to-write-sequences/33630/2 "2017-10-19T12:57:04Z")
</div>
_In reply to [PK](https://verificationacademy.com/forums/t/best-method-to-write-sequences/33630):_
It would be good if you could explain what your objective si and why you are going this way. In my eyes this has nothing todo with layered sequences. It looks like you are working with virtual seqúences.
I do not see what your m\_sequencer is.
