# Backdoor acess through user defined maps
**URL:** <https://verificationacademy.com/forums/t/backdoor-acess-through-user-defined-maps/33971>\
**Tags:** uvm\_reg\_map, UVM, DPI-backdoor-access\
**Created:** [January 24, 2018, 6:18am UTC](https://verificationacademy.com/forums/t/backdoor-acess-through-user-defined-maps/33971 "2018-01-24T06:18:49Z")\
**Showing post:** 4
**Author:** ![UnnikrishnanSNath](https://verificationacademy.com/forums/letter_avatar_proxy/v4/letter/u/c68b51/32.png) [@UnnikrishnanSNath](https://verificationacademy.com/forums/u/UnnikrishnanSNath)\
**Post date:** [January 24, 2018, 8:39am UTC](https://verificationacademy.com/forums/t/backdoor-acess-through-user-defined-maps/33971/4 "2018-01-24T08:39:19Z")
_In reply to [cuonghl](https://verificationacademy.com/forums/t/backdoor-acess-through-user-defined-maps/33971/3):_
> _In reply to [usnath](https://verificationacademy.com/forums/t/backdoor-acess-through-user-defined-maps/33971/3):_
> Why do you think register backdoor access is related to register map?
> The flow that you need to do to access a register value using backdoor:
- Provide hdl\_path (size and offset as well) which is pointed to RTL register using add\_hdl\_path/add\_hdl\_path\_slice.
- Use provided functions to read/write backdoor such as peek, poke, mirror, etc.
My register backdoor write test failed when I added another map in the child class of the reg\_top. The default map is added to the new map using add\_submap.
_[View the full topic](https://verificationacademy.com/forums/t/backdoor-acess-through-user-defined-maps/33971)._
