# Avoiding base class tasks to run in derived class
**URL:** <https://verificationacademy.com/forums/t/avoiding-base-class-tasks-to-run-in-derived-class/39953>\
**Category:** UVM\
**Tags:** UVM, sytemverilog\
**Created:** [January 11, 2022, 4:50am UTC](https://verificationacademy.com/forums/t/avoiding-base-class-tasks-to-run-in-derived-class/39953 "2022-01-11T04:50:40Z")\
**Posts on this page:** 2\
**Page:** 1
<div class="post-metadata">
**Author:** ![kritikagoell](https://verificationacademy.com/forums/letter_avatar_proxy/v4/letter/k/ebca7d/32.png) [@kritikagoell](https://verificationacademy.com/forums/u/kritikagoell)\
**Post date:** [January 11, 2022, 4:50am UTC](https://verificationacademy.com/forums/t/avoiding-base-class-tasks-to-run-in-derived-class/39953/1 "2022-01-11T04:50:40Z")
</div>
Hi Everyone,
I have a doubt. Suppose there is base class which contain all the task and function definitions which are being used/called in child classes dervied from base class.But there would be some other tasks or function which would be called automatically as part of the flow in the task body of base class. If I dont’t want to run or call that function of base class, what can be done for the same?
```verilog
class my_base extends uvm_test;
  `uvm_component_utils(base)
 function new(string name = "my_base" );
  super.new(name)
  virtual task body();
   //Task Definition_1
     task disp();
      $display("I am task 1" );
     endtask : disp //Task Disp Ends here
   //Task Definition_2
     task zisp();
      $display("I am task 2" );
     endtask : zisp //Task Zisp Ends here
     junk_job();
  endtask :body //Task body ends here
   task junk_job(); // Task junk definition
    $display("I am junk job");
   endtask : junk
 endclass[\systemverilog]
// Derived Class
  class my_derived extends my_base();
     `uvm_component_utils(my_derived)
 function new(string name = "my_derived" );
  super.new(name)
  task body();
   super.body();
   task der();
    $display("I am called from Derived");
   endtask : der
  endtask : body
Now due to inheritence property all the tasks of body of base will be available and will run in derived class. I do not want to run junk_job() in my derived class. How this can be achieved?
**Author:** ![KillSteal](https://verificationacademy.com/forums/letter_avatar_proxy/v4/letter/k/74df32/32.png) [@KillSteal](https://verificationacademy.com/forums/u/KillSteal)\
**Post date:** [January 11, 2022, 6:32am UTC](https://verificationacademy.com/forums/t/avoiding-base-class-tasks-to-run-in-derived-class/39953/2 "2022-01-11T06:32:43Z")
</div>
_In reply to [kritikagoell](https://verificationacademy.com/forums/t/avoiding-base-class-tasks-to-run-in-derived-class/39953):_
The answer is in your question.
Notice how body is “virtual” and there is a call to super.body in the extended class’s body task?
If you were to make junk\_job virtual, add the task to the extended class, and not do anything inside the task…
