# Assigning weak1 and weak0 to an input pin to verify pulldown
**URL:** <https://verificationacademy.com/forums/t/assigning-weak1-and-weak0-to-an-input-pin-to-verify-pulldown/31654>\
**Tags:** System-Verilog, UVM, drive-strength, weak-values, pulldown\
**Created:** [March 30, 2016, 11:31pm UTC](https://verificationacademy.com/forums/t/assigning-weak1-and-weak0-to-an-input-pin-to-verify-pulldown/31654 "2016-03-30T23:31:58Z")\
**Showing post:** 4
**Post date:** [March 31, 2016, 11:37am UTC](https://verificationacademy.com/forums/t/assigning-weak1-and-weak0-to-an-input-pin-to-verify-pulldown/31654/4 "2016-03-31T11:37:40Z")
_In reply to [szy0014](https://verificationacademy.com/forums/t/assigning-weak1-and-weak0-to-an-input-pin-to-verify-pulldown/31654/3):_
Drive strength does not play a role in an class-based environment. It is usually used in direct contact to the DUT. Best is to have some additional assigments in your SV interfaace construct. This does not generate aditional logic because will not be synthesized.
_[View the full topic](https://verificationacademy.com/forums/t/assigning-weak1-and-weak0-to-an-input-pin-to-verify-pulldown/31654)._
