# Assertions to check parameters
**URL:** <https://verificationacademy.com/forums/t/assertions-to-check-parameters/32878>\
**Category:** SystemVerilog\
**Tags:** SVA, system-verilog-assertion, SystemVerilog\
**Created:** [February 18, 2017, 10:23pm UTC](https://verificationacademy.com/forums/t/assertions-to-check-parameters/32878 "2017-02-18T22:23:57Z")\
**Showing post:** 2
**Post date:** [February 18, 2017, 11:38pm UTC](https://verificationacademy.com/forums/t/assertions-to-check-parameters/32878/2 "2017-02-18T23:38:58Z")
_In reply to [svishnu](https://verificationacademy.com/forums/t/assertions-to-check-parameters/32878):_
> I have two top level parameters in my module WIDTH and HEIGHT.
> The use case of this module is such that WIDTH should always be less than HEIGHT.
> is it possible to write an system verilog assertion just to check if this condition is always satisfied? should I use concurrent assertions or immediate assertions? is this(using sva) the best way to do it?
I would write something like the following since parameters are evaluated at elaboration time, and remain unchanged throughout the simulation.
```verilog
module m #(WIDTH=3, HEIGHT=2) (input bit a);
  initial
   ap_wh: assert(WIDTH < HEIGHT);
"testbench.sv", 5: m.ap_wh: started at 0ns failed at 0ns
	Offending '(WIDTH < HEIGHT)'
https://www.edaplayground.com/x/42SK
- [SVA Handbook 4th Edition, 2016 ISBN 978-1518681448](http://goo.gl/JOfuEB)
- [Real Chip Design and Verification Using Verilog and VHDL, 2002 isbn 978-1539769712](https://goo.gl/d10QHh)
_[View the full topic](https://verificationacademy.com/forums/t/assertions-to-check-parameters/32878)._
