# Assertion to check valid transition from value A to value B on a bus and this transition is only valid when strobe is high. If I try to use $past(bus== A) -\> (bus ==B) & (strobe ==1). It does not work
**URL:** <https://verificationacademy.com/forums/t/assertion-to-check-valid-transition-from-value-a-to-value-b-on-a-bus-and-this-transition-is-only-valid-when-strobe-is-high-if-i-try-to-use-past-bus-a-bus-b-strobe-1-it-does-not-work/37157>\
**Category:** SystemVerilog\
**Tags:** SVA, SystemVerilog, past\
**Created:** [February 9, 2020, 6:58pm UTC](https://verificationacademy.com/forums/t/assertion-to-check-valid-transition-from-value-a-to-value-b-on-a-bus-and-this-transition-is-only-valid-when-strobe-is-high-if-i-try-to-use-past-bus-a-bus-b-strobe-1-it-does-not-work/37157 "2020-02-09T18:58:53Z")\
**Showing post:** 2
**Post date:** [February 9, 2020, 8:49pm UTC](https://verificationacademy.com/forums/t/assertion-to-check-valid-transition-from-value-a-to-value-b-on-a-bus-and-this-transition-is-only-valid-when-strobe-is-high-if-i-try-to-use-past-bus-a-bus-b-strobe-1-it-does-not-work/37157/2 "2020-02-09T20:49:43Z")
_In reply to [shals](https://verificationacademy.com/forums/t/assertion-to-check-valid-transition-from-value-a-to-value-b-on-a-bus-and-this-transition-is-only-valid-when-strobe-is-high-if-i-try-to-use-past-bus-a-bus-b-strobe-1-it-does-not-work/37157):_
Your requirements are not clear.
```verilog
let A=2'b10; let B=2'b11;
ap_strobe: assert property(@(posedge clk) strobe |-> $past(bus== A) && (bus ==B) );
/* above says that
   when strobe==1, current value of bus==A, and past value of bus as B
For training, consulting, services: contact [Home - My cvcblr](http://cvcblr.com/home)
- [SVA Handbook 4th Edition, 2016 ISBN 978-1518681448](http://goo.gl/JOfuEB)
- [Real Chip Design and Verification Using Verilog and VHDL, 2002 isbn 978-1539769712](https://goo.gl/d10QHh)
1. SVA Alternative for Complex Assertions
[Verification Horizons - March 2018 Issue | Verification Academy](https://verificationacademy.com/news/verification-horizons-march-2018-issue)
2. [SVA: Package for dynamic and range delays and repeats | Verification Academy](https://verificationacademy.com/forums/systemverilog/sva-package-dynamic-and-range-delays-and-repeats)
3. SVA in a UVM Class-based Environment
[SVA in a UVM Class-based Environment | Verification Horizons | Verification Academy](https://verificationacademy.com/verification-horizons/february-2013-volume-9-issue-1/SVA-in-a-UVM-Class-based-Environment)
_[View the full topic](https://verificationacademy.com/forums/t/assertion-to-check-valid-transition-from-value-a-to-value-b-on-a-bus-and-this-transition-is-only-valid-when-strobe-is-high-if-i-try-to-use-past-bus-a-bus-b-strobe-1-it-does-not-work/37157)._
