# Assertion to check if A does not rise between pulse B and Pulse C
**URL:** <https://verificationacademy.com/forums/t/assertion-to-check-if-a-does-not-rise-between-pulse-b-and-pulse-c/30429>\
**Category:** SystemVerilog\
**Tags:** SystemVerilog, assertion-systemverilog\
**Created:** [March 7, 2015, 3:51am UTC](https://verificationacademy.com/forums/t/assertion-to-check-if-a-does-not-rise-between-pulse-b-and-pulse-c/30429 "2015-03-07T03:51:06Z")\
**Showing post:** 4
**Post date:** [March 18, 2015, 4:35pm UTC](https://verificationacademy.com/forums/t/assertion-to-check-if-a-does-not-rise-between-pulse-b-and-pulse-c/30429/4 "2015-03-18T16:35:33Z")
_In reply to [cool\_cake20](https://verificationacademy.com/forums/t/assertion-to-check-if-a-does-not-rise-between-pulse-b-and-pulse-c/30429/3):_
What I initially wrote was correct for the original requirements:
“Pulse A should **not fall** between these two pulses(B and C). It be either before B or after C.”
meaning (my interpretation) that if A==0, it should fail.
ap\_abc: assert property(reject\_on (!a) // reject if a==0, since !a==1, and abort condition is true
@(posedge b) 1’b1 |-\> @(posedge c) 1’b1); / is correct.
For this requirement
“If in between B and C there may be any number of clock cycles like [1:$] in a given simulation but A should **not be become high** (meaning must be 0, if 1 → fail) in between B and C.” then
ap\_abc: assert property(reject\_on (a)
From the syntax of a property
property\_expr ::= // includes
reject\_on ( expression\_or\_dist ) property\_expr
Thus,
assert property (@(posedge clk) rose(b) |-\> (reject\_on(a) ##[1:] c); // is correct
// The " c[1:]" is incorect, unless you mean c[\*1:], which is a repeat operator
- SystemVerilog Assertions Handbook 3rd Edition, 2013 ISBN 878-0-9705394-3-6
_[View the full topic](https://verificationacademy.com/forums/t/assertion-to-check-if-a-does-not-rise-between-pulse-b-and-pulse-c/30429)._
