# Assertion property to check for toggle count of a signal between two control signals
**URL:** <https://verificationacademy.com/forums/t/assertion-property-to-check-for-toggle-count-of-a-signal-between-two-control-signals/41282>\
**Category:** SystemVerilog\
**Tags:** System-Verilog, SystemVerilog, assertion\
**Created:** [February 16, 2023, 5:57am UTC](https://verificationacademy.com/forums/t/assertion-property-to-check-for-toggle-count-of-a-signal-between-two-control-signals/41282 "2023-02-16T05:57:58Z")\
**Showing post:** 2
**Author:** ![peter1](https://verificationacademy.com/forums/user_avatar/verificationacademy.com/peter1/32/1304_2.png) [@peter1](https://verificationacademy.com/forums/u/peter1)\
**Post date:** [February 17, 2023, 1:26am UTC](https://verificationacademy.com/forums/t/assertion-property-to-check-for-toggle-count-of-a-signal-between-two-control-signals/41282/2 "2023-02-17T01:26:04Z")
_In reply to [ben@SystemVerilog.us](https://verificationacademy.com/forums/t/assertion-property-to-check-for-toggle-count-of-a-signal-between-two-control-signals/41282):_
Hi Ben
What is the problem in original code?
##1 rose(req) |-\> strong(vld[=10] ##[1:] $rose(ack));
Thank you!
_[View the full topic](https://verificationacademy.com/forums/t/assertion-property-to-check-for-toggle-count-of-a-signal-between-two-control-signals/41282)._
