# Assertion Problem
**URL:** <https://verificationacademy.com/forums/t/assertion-problem/39143>\
**Category:** SystemVerilog\
**Tags:** SystemVerilog, assertion\
**Created:** [June 3, 2021, 6:50pm UTC](https://verificationacademy.com/forums/t/assertion-problem/39143 "2021-06-03T18:50:39Z")\
**Posts on this page:** 4\
**Page:** 1
<div class="post-metadata">
**Author:** ![Abhishek405](https://verificationacademy.com/forums/letter_avatar_proxy/v4/letter/a/9fc348/32.png) [@Abhishek405](https://verificationacademy.com/forums/u/Abhishek405)\
**Post date:** [June 3, 2021, 6:50pm UTC](https://verificationacademy.com/forums/t/assertion-problem/39143/1 "2021-06-03T18:50:39Z")
</div>
What would be the right assertion to capture this behavior → signal A (level or pulse) rises only once after signal B(pulse)?
**Post date:** [June 3, 2021, 10:08pm UTC](https://verificationacademy.com/forums/t/assertion-problem/39143/2 "2021-06-03T22:08:52Z")
</div>
_In reply to [letzask](https://verificationacademy.com/forums/t/assertion-problem/39143):_
A few questions:
Do you mean to say A rises only once after B rises; until B rises again, or A must never rise again?
Are A and B synchronous to a clock or asynchronous?
**Post date:** [June 3, 2021, 10:19pm UTC](https://verificationacademy.com/forums/t/assertion-problem/39143/3 "2021-06-03T22:19:30Z")
</div>
_In reply to [dave\_59](https://verificationacademy.com/forums/t/assertion-problem/39143/2):_
This is the requirement: A rises only once after B rises; until B rises again
Also, A & B are synchronous to a clock.
**Post date:** [June 4, 2021, 3:40am UTC](https://verificationacademy.com/forums/t/assertion-problem/39143/4 "2021-06-04T03:40:16Z")
</div>
_In reply to [letzask](https://verificationacademy.com/forums/t/assertion-problem/39143/3):_
I believe this is the same requirement: [how to write the assertion that between two requests grant should be there | Verification Academy](https://verificationacademy.com/forums/systemverilog/how-write-assertion-between-two-requests-grant-should-be-there#reply-98094)
