# Assertion for signal stability inside a window
**URL:** <https://verificationacademy.com/forums/t/assertion-for-signal-stability-inside-a-window/37358>\
**Category:** SystemVerilog\
**Tags:** SVA, throughout, SystemVerilog, rose, assert, stable\
**Created:** [March 25, 2020, 1:37pm UTC](https://verificationacademy.com/forums/t/assertion-for-signal-stability-inside-a-window/37358 "2020-03-25T13:37:07Z")\
**Showing post:** 2
**Post date:** [March 25, 2020, 6:28pm UTC](https://verificationacademy.com/forums/t/assertion-for-signal-stability-inside-a-window/37358/2 "2020-03-25T18:28:46Z")
_In reply to [alexkidd84](https://verificationacademy.com/forums/t/assertion-for-signal-stability-inside-a-window/37358):_
Your requirements are not clear; I believe that this is what you are trying to express:
At (fell(a) && !b) then starting from the next clock “c” holds the value it had at the fell(a)
until a rose(a). At the rose(a), “c” can change value.
```verilog
//my purpose is to check that 'c' is stable since a fell down (and b is low)
    //and until a goes high again.
    property p_cstable;
        bit v;
        @(posedge clk) disable iff (!reset_n)
        ($fell(a) && !b, v=c )|=> c==v s_until $rose(a);
    ap_c_stable: assert property(p_cstable);
If this is not your requirements, then please re-express them again.
For training, consulting, services: contact [Home - My cvcblr](http://cvcblr.com/home)
- [SVA Handbook 4th Edition, 2016 ISBN 978-1518681448](http://goo.gl/JOfuEB)
- [Real Chip Design and Verification Using Verilog and VHDL, 2002 isbn 978-1539769712](https://goo.gl/d10QHh)
1. SVA Alternative for Complex Assertions
[Verification Horizons - March 2018 Issue | Verification Academy](https://verificationacademy.com/news/verification-horizons-march-2018-issue)
2. [SVA: Package for dynamic and range delays and repeats | Verification Academy](https://verificationacademy.com/forums/systemverilog/sva-package-dynamic-and-range-delays-and-repeats)
3. SVA in a UVM Class-based Environment
[SVA in a UVM Class-based Environment | Verification Horizons | Verification Academy](https://verificationacademy.com/verification-horizons/february-2013-volume-9-issue-1/SVA-in-a-UVM-Class-based-Environment)
_[View the full topic](https://verificationacademy.com/forums/t/assertion-for-signal-stability-inside-a-window/37358)._
