# Assertion failing - no clue why!
**URL:** <https://verificationacademy.com/forums/t/assertion-failing-no-clue-why/34393>\
**Category:** SystemVerilog\
**Tags:** System-Verilog, SystemVerilog, Assertion-system-verilog, assertion\
**Created:** [April 25, 2018, 9:50pm UTC](https://verificationacademy.com/forums/t/assertion-failing-no-clue-why/34393 "2018-04-25T21:50:32Z")\
**Posts on this page:** 6\
**Page:** 1
<div class="post-metadata">
**Author:** ![somys](https://verificationacademy.com/forums/letter_avatar_proxy/v4/letter/s/f1d935/32.png) [@somys](https://verificationacademy.com/forums/u/somys)\
**Post date:** [April 25, 2018, 9:50pm UTC](https://verificationacademy.com/forums/t/assertion-failing-no-clue-why/34393/1 "2018-04-25T21:50:32Z")
</div>
I am writing this assertion on the output signals of a module:
Requirement:
After the signal\_eop happens, data valid should remain low for that port\_id until signal\_sop occurs for that same port\_id.
property ChkDataValid;
int id;
@( posedge clk ) disable iff ( !rst\_l )
( $rose(signal\_eop), id=src\_port)
|=\> (!(data\_valid & (src\_port == id))) throughout ( (($rose(signal\_sop)) && (src\_port == id))[-\>1] );
assert property ( ChkDataValid );
In my design, signal\_eop rises on 1st clock cycle when data\_valid=1 and src\_port=0 and then on 2nd clock cycle signal\_eop holds high but data\_valid transitions to 0 with src\_port=0. It fails on 2nd clock cycle.
please help me figure out what may be wrong with my assertion.
Thanks a lot.
**Author:** ![user49](https://verificationacademy.com/forums/user_avatar/verificationacademy.com/user49/32/4533_2.png) [@user49](https://verificationacademy.com/forums/u/user49)\
**Post date:** [April 25, 2018, 11:21pm UTC](https://verificationacademy.com/forums/t/assertion-failing-no-clue-why/34393/2 "2018-04-25T23:21:10Z")
</div>
_In reply to [somys](https://verificationacademy.com/forums/t/assertion-failing-no-clue-why/34393):_
You error is in the location of the “!” operator
```verilog
You have:
(!(data_valid & (src_port==id))) throughout ( (($rose(signal_sop)) && (src_port == id))[->1] );
Should be:
(!data_valid && src_port==id) throughout ($rose(signal_sop) && src_port==id)[->1];
BTW, you have way too many parentheses, makes code hard to follow.
[http://www.systemverilog.us/](http://www.systemverilog.us/) [ben@systemverilog.us](mailto:ben@systemverilog.us)
For training, consulting, services: contact [Home - My cvcblr](http://cvcblr.com/home)
- [SVA Handbook 4th Edition, 2016 ISBN 978-1518681448](http://goo.gl/JOfuEB)
- [Real Chip Design and Verification Using Verilog and VHDL, 2002 isbn 978-1539769712](https://goo.gl/d10QHh)
- A Pragmatic Approach to VMM Adoption 2006 ISBN 0-9705394-9-5
- Using PSL/SUGAR for Formal and Dynamic Verification 2nd Edition, 2004, ISBN 0-9705394-6-0
- Component Design by Example ", 2001 ISBN 0-9705394-0-1
- VHDL Coding Styles and Methodologies, 2nd Edition, 1999 ISBN 0-7923-8474-1
- VHDL Answers to Frequently Asked Questions, 2nd Edition ISBN 0-7923-8115
See Paper: [VF Horizons:PAPER: SVA Alternative for Complex Assertions | Verification Academy](https://verificationacademy.com/forums/systemverilog/vf-horizonspaper-sva-alternative-complex-assertions)
**Post date:** [April 26, 2018, 4:56pm UTC](https://verificationacademy.com/forums/t/assertion-failing-no-clue-why/34393/3 "2018-04-26T16:56:07Z")
</div>
_In reply to [ben@SystemVerilog.us](https://verificationacademy.com/forums/t/assertion-failing-no-clue-why/34393/2):_
> _In reply to [somys](https://verificationacademy.com/forums/t/assertion-failing-no-clue-why/34393/2):_
> You have:
> (!(data\_valid & (src\_port==id))) throughout ( (($rose(signal\_sop)) && (src\_port == id))[-\>1] );
> Should be:
> (!data\_valid && src\_port==id) throughout ($rose(signal\_sop) && src\_port==id)[-\>1];
Thanks a lot for replying.
In my case, the src\_port can be different than “id” at times and for those id’s, data valid is allowed to be 1 after $rose(signal\_eop) is seen for a specific ID. data valid should be 0 until $rose(signal\_sop) is seen for that same ID.
Doesn’t your solution require data\_valid=0 and src\_port==id all the time? and not allow src\_port to be any different than that specific ID?
please explain since I am at loss with this understanding. Thanks a lot.
**Post date:** [April 26, 2018, 6:09pm UTC](https://verificationacademy.com/forums/t/assertion-failing-no-clue-why/34393/4 "2018-04-26T18:09:33Z")
</div>
_In reply to [somys](https://verificationacademy.com/forums/t/assertion-failing-no-clue-why/34393/3):_
You need to clearly write your requirements in English.
It sounds like what you want is that for every associated data\_valid && src\_port pair
data\_valid==0 until ($rose(signal\_sop) && src\_port==id)[-\>1].
Is this what you want?
See if this will work:
```verilog
 first_match(
     (!data_valid && src_port==id ##[0:$]src_port!=id) [*0:$] ##1
Ben [Ben@systemverilog.us](mailto:Ben@systemverilog.us)
**Post date:** [April 26, 2018, 8:14pm UTC](https://verificationacademy.com/forums/t/assertion-failing-no-clue-why/34393/5 "2018-04-26T20:14:14Z")
</div>
_In reply to [ben@SystemVerilog.us](https://verificationacademy.com/forums/t/assertion-failing-no-clue-why/34393/4):_
Ben,
thanks again. Would you please explain me this statement?
(!data\_valid && src\_port==id ##[0:$]src\_port!=id)
Does this mean data\_valid=0 when src\_port==id and then src\_port!=id after that until signal\_sop happens?
I just need data\_valid=0 whenever src\_port==id after the signal\_eop. Other than that both data\_valid and src\_port can take any values until signal\_sop.
Thanks.
**Post date:** [April 26, 2018, 10:01pm UTC](https://verificationacademy.com/forums/t/assertion-failing-no-clue-why/34393/6 "2018-04-26T22:01:47Z")
</div>
_In reply to [somys](https://verificationacademy.com/forums/t/assertion-failing-no-clue-why/34393/5):_
```verilog
The sequence (à ##[0:$]b) is same as
a or a ##1 b or a ##2 b or... a ##n b
Thus,
Says
 (!data_valid && src_port==I'd) can be followed by 0 or cycles of
     src_port!=id). With the [*0:$] that sequence is repeated indefinitely until
Hope that clarifies things. The first_match is not really needed, but it is needed if you follow it with another test condition; I. E. first_match(some_sequence) ##0 seq
Ben [systemverilog.us](http://systemverilog.us)
