# Any use case where we should be creating a new transaction(using factory create) for every iteration in a sequence?
**URL:** <https://verificationacademy.com/forums/t/any-use-case-where-we-should-be-creating-a-new-transaction-using-factory-create-for-every-iteration-in-a-sequence/36044>\
**Tags:** uvm-factory, UVM, randomization, uvm-sequence-item\
**Created:** [May 2, 2019, 5:27am UTC](https://verificationacademy.com/forums/t/any-use-case-where-we-should-be-creating-a-new-transaction-using-factory-create-for-every-iteration-in-a-sequence/36044 "2019-05-02T05:27:36Z")\
**Showing post:** 2
**Author:** ![tfitz](https://verificationacademy.com/forums/user_avatar/verificationacademy.com/tfitz/32/3025_2.png) [@tfitz](https://verificationacademy.com/forums/u/tfitz)\
**Post date:** [May 2, 2019, 2:20pm UTC](https://verificationacademy.com/forums/t/any-use-case-where-we-should-be-creating-a-new-transaction-using-factory-create-for-every-iteration-in-a-sequence/36044/2 "2019-05-02T14:20:11Z")
_In reply to [sj1992](https://verificationacademy.com/forums/t/any-use-case-where-we-should-be-creating-a-new-transaction-using-factory-create-for-every-iteration-in-a-sequence/36044):_
As long as one transaction completes before you need to start another one, then you can get away with just creating a single transaction/seq\_item and reusing it on each pass through your loop. Just be aware that if you need to preserve the contents of the transaction in a monitor or scoreboard, then you must follow the [MCOW rule](https://verificationacademy.com/cookbook/uvm/guidelines) (Guideline 10.1).
_[View the full topic](https://verificationacademy.com/forums/t/any-use-case-where-we-should-be-creating-a-new-transaction-using-factory-create-for-every-iteration-in-a-sequence/36044)._
