# @always position
**URL:** <https://verificationacademy.com/forums/t/always-position/38577>\
**Category:** SystemVerilog\
**Tags:** always, SystemVerilog, Verilog\
**Created:** [January 12, 2021, 12:46pm UTC](https://verificationacademy.com/forums/t/always-position/38577 "2021-01-12T12:46:55Z")\
**Posts on this page:** 3\
**Page:** 1
<div class="post-metadata">
**Author:** ![likhith\_bommu](https://verificationacademy.com/forums/letter_avatar_proxy/v4/letter/l/ac91a4/32.png) [@likhith\_bommu](https://verificationacademy.com/forums/u/likhith_bommu)\
**Post date:** [January 12, 2021, 12:46pm UTC](https://verificationacademy.com/forums/t/always-position/38577/1 "2021-01-12T12:46:55Z")
</div>
Can somebody explain the difference between these two code blocks?
1st block:
@always(posedge clock) begin
b = c;
a = d;
e \<= f;
g \<= h;
2nd block:
b = c;
a = d;
e \<= f;
g \<= h;
@always(posedge clock) end
Will the two blocks behave differently? If not in this case, is there any other case you can explain where they behave differently.
Thanks.
**Post date:** [January 12, 2021, 7:55pm UTC](https://verificationacademy.com/forums/t/always-position/38577/2 "2021-01-12T19:55:12Z")
</div>
_In reply to [likhith bommu](https://verificationacademy.com/forums/t/always-position/38577):_
Both code blocks or not legal syntax. Please show complete examples to make sure the know the context of the question.
See [Asking better questions on the Verification Academy Forums with EDAPlayground - Verification Horizons](https://blogs.sw.siemens.com/verificationhorizons/2020/04/29/forums-with-edaplayground/)
**Post date:** [January 16, 2021, 3:06pm UTC](https://verificationacademy.com/forums/t/always-position/38577/3 "2021-01-16T15:06:09Z")
</div>
Sorry for not providing complete code. I tried to create 2 modules. Hope this will help you to understand my question.
module scene\_one (input clock,input a, input b, input c, input d, output reg o, output reg o\_d);
always @ (posedge clock) begin
o = ~((a & b) | (c^d));
o\_d \<= o;
module scene\_two (input clock,input a, input b, input c, input d, output reg o, output reg o\_d);
o\_d \<= o;
always @ (posedge clock);
Can you explain how each module samples the data and provides the output?
